I recently (two days ago) started using the Flightaware 1090MHz PiAware ADS-B Kit. Initially everything we working well (over 1000 flights tracked per day) and then the Pi started reporting the errors:
[2022-08-13 16:55 EDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2022-08-13 16:55 EDT] 0 msgs recv’d from dump1090; 0 msgs sent to FlightAware
[2022-08-13 16:56 EDT] no ADS-B data program seen listening on port 30005 for 63 seconds, next check in 60s
This continues on and on.
Unplugging and plugging in the Pi does not correct. Restarting the Pi does not correct. Restarting Piaware and/or dump1090 does not correct. Unplugging the ADS-B stick does not correct.
Took a bit to check what you suggested as I didn’t have a screen or keyboard connected to the Pi.
As such I needed to get a micro to usb hub to connect the keyboard and a HDMI cable.
Installed the HDMI cable and the status screen on the Pi showed no receiver connected.
Removing the original micro to usb cable and then connecting the hub caused the Pi to reboot and when it came back up the SDR stick was recognized and the Pi started sending data.
At this point it likely is the cable causing the issue, though I can’t see an obvious problem with the pins or connectors. I’ll let things be as they are with the new cable and if it fails again I’ll run the test on the Pi as suggested and see what that says and post more information here.
