I’m trying to setup a nginx reverse proxy to my PiAware. Currently, I’m getting "The connection is not fully secure due to a “non-secure form”.
Seems like an issue with the “airframes_post” form using HTTP and not HTTPS. Do anyone have any ideas to get nginx reverse proxy working correctly or how to workaround the airframes_post form connecting over HTTP?
Given that, afaik, airframes.org doesn’t support https and there’s no other way to embed the query other than the form hackery, this seems unavoidable. You could remove the airframes form stuff entirely if you don’t need it.
That’s unfortunate that airframes.org lack of support for HTTPS is bringing down the overall security of PiAware. I wouldn’t want to break my PiAware with too much hackery, but would like a fully SSL secure option. Have others setup full SSL reverse proxy that can help me out here?
It’s not really related to PiAware/SkyAware at all; it’s a third party site which doesn’t provide friendly scheme for external queries, so embedding a form is the only way I could make it work. None of skyaware loads from there and the only data that would be submitted over HTTP is the ICAO address of an aircraft that you clicked on the link for (+ the usual headers). If you don’t click the link, nothing goes over HTTP.
Also easy enough to set up nginx directly on the RPi and serve tar1090 with the nginx configuration file the installer creates, all you need to do is include it in your nginx config.
You could also serve Skyaware from nginx without issues, the configuration isn’t hard.
