For about the last 2 weeks my dump from my unit has not worked, although I am still live with my feeds to FA. I have been having some IP address issues on my local net and did replace by modem, but that is not a current problem. All else is working fine on my system. Any thoughts would be appreciated. (I have, of course, rebooted my unit several times).
Steve Cantrill
obj
February 24, 2017, 6:01pm
2
Your stats page (flightaware.com/adsb/stats/user/scantrill ) reports a different local IP for your piaware, not .97. Probably the modem change has caused a different local IP to be assigned to your piaware, so you’re just looking at the wrong address. Try following the “view live data” link on the stats page.
pp8kwa
March 2, 2017, 9:59pm
4
Hi.
I have this issue also. My local page 192.168.0.5:8080, dont work.
The IP is correct.
Jefferson
pp8kwa
March 4, 2017, 1:56pm
6
Hi.
The IP is correct.
It looks like lighttpd does not go up.
Thanks.
1 ? 00:00:21 systemd
2 ? 00:00:00 kthreadd
3 ? 00:00:05 ksoftirqd/0
6 ? 00:00:00 migration/0
7 ? 00:00:03 watchdog/0
8 ? 00:00:00 migration/1
9 ? 00:01:07 kworker/1:0
10 ? 00:00:02 ksoftirqd/1
11 ? 00:00:03 watchdog/1
12 ? 00:00:00 migration/2
14 ? 00:00:04 ksoftirqd/2
15 ? 00:00:03 watchdog/2
16 ? 00:00:00 migration/3
17 ? 00:00:00 kworker/3:0
18 ? 00:00:01 ksoftirqd/3
19 ? 00:00:03 watchdog/3
20 ? 00:00:00 cpuset
21 ? 00:00:00 khelper
22 ? 00:00:00 kdevtmpfs
23 ? 00:00:00 netns
24 ? 00:00:00 kworker/0:1
26 ? 00:03:21 kworker/2:1
27 ? 00:00:32 kworker/3:1
28 ? 00:00:01 sync_supers
29 ? 00:00:00 bdi-default
30 ? 00:00:00 kintegrityd
31 ? 00:00:00 crypto
32 ? 00:00:00 kblockd
33 ? 00:00:00 sytem
34 ? 00:00:00 khubd
35 ? 00:00:00 cfg80211
36 ? 00:00:00 rpciod
37 ? 00:00:00 khungtaskd
38 ? 00:00:01 kswapd0
39 ? 00:00:00 vmstat
40 ? 00:00:00 fsnotify_mark
41 ? 00:00:00 nfsiod
42 ? 00:00:00 cifsiod
57 ? 00:00:00 SunxiDisCommit
58 ? 00:00:00 kapmd
59 ? 00:00:00 spi.0
67 ? 00:03:12 cfinteractive
68 ? 00:00:01 kworker/u:2
69 ? 00:00:00 kworker/u:3
71 ? 00:13:31 kworker/0:2
72 ? 00:00:13 mmcqd/0
73 ? 00:00:56 hdmi proc
74 ? 00:00:00 deferwq
75 ? 00:00:00 thermal_wq
77 ? 00:00:00 devfreq_wq
115 ? 00:00:00 kworker/1:2
136 ? 00:00:00 jbd2/mmcblk0p1-
137 ? 00:00:00 ext4-dio-unwrit
173 ? 00:00:00 mali-pmm-wq
179 ? 00:00:00 kauditd
207 ? 00:00:01 systemd-udevd
235 ? 00:01:34 haveged
285 ? 00:04:30 systemd-journal
491 ? 00:01:03 accounts-daemon
492 ? 00:00:00 avahi-daemon
496 ? 00:00:00 avahi-daemon
497 ? 00:00:01 systemd-logind
540 ? 00:00:01 cron
547 ? 00:01:05 rsyslogd
563 ? 00:00:05 dbus-daemon
614 ? 00:03:50 NetworkManager
640 ? 00:00:00 nodm
648 tty7 00:00:06 Xorg
691 ? 00:00:00 dhclient
731 ? 00:00:16 sshd
743 ? 00:00:03 polkitd
779 ? 00:00:00 nodm
806 ? 00:00:00 systemd
830 ? 00:00:00 (sd-pam)
872 ? 00:00:00 dnsmasq
927 ? 00:00:45 ntpd
947 ? 00:00:00 sh
948 tty1 00:00:00 agetty
951 ? 00:00:00 sh
962 ttyS0 00:00:00 agetty
1008 ? 00:00:02 ssh-agent
1011 ? 00:00:00 dbus-launch
1012 ? 00:00:01 dbus-daemon
1030 ? 00:00:00 xfce4-session
1051 ? 00:00:00 xfconfd
1055 ? 00:00:02 xfwm4
1059 ? 00:00:16 xfce4-panel
1061 ? 00:00:00 Thunar
1063 ? 00:00:13 xfdesktop
1064 ? 00:00:01 pasystray
1068 ? 00:00:00 xfsettingsd
1069 ? 00:00:02 blueman-applet
1073 ? 00:00:00 polkit-gnome-au
1080 ? 00:00:00 pulseaudio
1082 ? 00:00:00 gvfsd
1087 ? 00:00:00 gvfsd-fuse
1111 ? 00:00:00 gvfs-udisks2-vo
1118 ? 00:00:01 udisksd
1156 ? 00:00:00 gvfs-gphoto2-vo
1160 ? 00:00:00 panel-6-systray
1164 ? 00:00:00 panel-2-actions
1166 ? 00:00:00 gvfs-mtp-volume
1172 ? 00:00:00 gvfs-goa-volume
1177 ? 00:00:00 gvfs-afc-volume
1188 ? 00:00:00 gvfsd-trash
1221 ? 00:00:00 gvfsd-metadata
1258 ? 00:00:00 gconf-helper
1260 ? 00:00:00 gconfd-2
1465 ? 00:00:00 obexd
1493 ? 17:07:02 dump1090-fa
12050 ? 00:00:09 faup1090
13120 ? 00:00:00 gnome-keyring-d
13906 ? 00:00:00 sshd
13908 ? 00:00:00 systemd
13909 ? 00:00:00 (sd-pam)
13987 pts/0 00:00:01 bash
14072 pts/0 00:00:00 ps
20412 ? 00:00:00 dhclient
26533 ? 00:02:32 piaware
26548 ? 00:09:02 fa-mlat-client
29117 ? 00:00:00 kworker/2:0
eth0 Link encap:Ethernet HWaddr xx-xx-xx-xx-xx-xx
inet addr:192.168.0.5 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::b447:d8ff:feec:7d4f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:227107 errors:0 dropped:0 overruns:0 frame:0
TX packets:158398 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:88616624 (88.6 MB) TX bytes:25693796 (25.6 MB)
Interrupt:114
I was having this same issue.
I’m running apache and not lighttpd. I reconfigured lighttpd to use port 81 (since apache is on 80) and the live stats showed up as another site served by lighttpd on port 8080.
obj
March 23, 2017, 3:59pm
8
dump1090-fa does nothing to listen on port 8080. You must arrange for a webserver to serve the map there if you want it. The package provides a lighttpd configuration fragment that does this, but if you are using another webserver such as apache you need to configure that yourself.
