Multilateration data no longer required, disabling mlat client
Since I upgraded to piaware 10.0.1 my MLAT - will not stay running. On 9.X it would disconnect from time to time but normally I would see the green box on my stat page. After the upgrade my MLAT is always disabled. Now maybe because I have a very good location and I personally don’t need MLAT as only about 0.5% of my traffic is from MLAT but why does it not stay online for others to triangulate off of me? Basically about every minute, the mlat-client just chooses to shutdown and then a minute or so later restarts.
MLAT is enabled and my location is set by gpsd but should be a fixed location. Maybe the people that work on the code only enable the client when there is a plane without position information.
Apr 09 14:03:18 piaware2 piaware[3408365]: 1661 msgs recv'd from dump1090-fa; 1661 msgs sent to FlightAware
Apr 09 14:03:18 piaware2 piaware[3408365]: 62 msgs recv'd from dump978-fa; 62 msgs sent to FlightAware
Apr 09 14:03:50 piaware2 piaware[3408365]: multilateration data no longer required, disabling mlat client
Apr 09 14:03:51 piaware2 piaware[3408365]: fa-mlat-client exited normally
Apr 09 14:03:51 piaware2 piaware[3408365]: mlat-client(3408462): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
Apr 09 14:03:51 piaware2 piaware[3408365]: mlat-client(3408462): Exiting on connection loss
Apr 09 14:05:35 piaware2 piaware[3408365]: multilateration data requested
Apr 09 14:05:35 piaware2 sudo[3410573]:  piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Apr 09 14:05:35 piaware2 sudo[3410573]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=999)
Apr 09 14:05:35 piaware2 sudo[3410573]: pam_unix(sudo:session): session closed for user root
Apr 09 14:05:35 piaware2 piaware[3408365]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.84.195:17111:2446226625
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): fa-mlat-client 0.2.13 starting up
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Using UDP transport to 206.253.84.195 port 17111
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Listening for Beast-format results connection on port 30105
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Listening for Extended Basestation-format results connection on port 30106
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Route MTU changed to 1500
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Input connected to localhost:30005
Apr 09 14:05:35 piaware2 piaware[3408365]: mlat-client(3410575): Input format changed to BEAST, 12MHz clock
Apr 09 14:05:36 piaware2 piaware[3408365]: mlat-client(3410575): Beast-format results connection with ::1:30104: connection established
Apr 09 14:06:41 piaware2 piaware[3408365]: multilateration data no longer required, disabling mlat client
Apr 09 14:06:42 piaware2 piaware[3408365]: fa-mlat-client exited normally
Apr 09 14:06:42 piaware2 piaware[3408365]: mlat-client(3410575): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
Apr 09 14:06:42 piaware2 piaware[3408365]: mlat-client(3410575): Exiting on connection loss
Your mlat client is sending some malformed data, though I’m not immediately sure what the cause of that is.
What is the hardware, and how did you build or install piaware & mlat-client?
The original install was done around Oct 2023 on an raspbian lite install with the piaware packages added onto a raspberry pi 4. The 1090 radio is an airspy mini with some bias-t powered LNA that I can’t recall connected to FlightAware antenna. It was configured by the scripts provided by GitHub - wiedehopf/airspy-conf: Configure airspy_adsb for use with readsb or piaware.. The 978 radio is a RTL-SDR V3 connected to another Flightaware antenna. There also a cheap gps usb dongle configured via gpsd that works on startup about 75% of the time otherwise returns 00,00. After the upgrade to 10.0.1 via apt upgrade and a reboot. GPS was broken so I restarted gpsd and piaware and everything seemed fine. Around March of 2024 the PI was replaced with a PI5. This was done by just switching SD cards and apt upgrade commands. Lastly for completeness I have rbfeeder installed for AirNav, however I never configured MLAT for it as I did not want to deal with running another mlat client. I have stopped rbfeeder as of 8:30 am EDT and it does not seem to be affecting the fa-mlat-client from restarting. Lastly I can’t easily touch the current system as it is on top of a 130 ft tower.
Thanks for the info. I think I’ve identified the problem on our side (it affects only sites that can see a large number of aircraft simultaneously). I’ll let you know when I have an ETA for a fix.
Thank you. I also have been experiencing the MLAT function on my system turning itself on and off all day long. I lose it during high traffic periods of the day, and it stays active as the traffic diminishes later in the day. MLAT is currently shut down while the system is tracking 456 aircraft.
On my Debian trixie/sid on PC (x86_64) and on Armbian trixie/sid on RPi4 (aarch64), it only occassionally happens, not so frequent as what you have described.
It’s been going on here for a number of months now and don’t recall the actual start. I was accepting it as a result of the MLAT protocol seeing my MLAT data as possibly redundant to existing system data and was shutting my local process down since it was no longer needed by the system. It would revert to running in “Beast” format and then again shut down shortly thereafter. Thought it rather odd but made no pretense of understanding the MLAT theory of operation.
Log:
2025-04-10 15:24 EDT] mlat-client(28329): Beast-format results connection with ::1:30104: connection established
[2025-04-10 15:25 EDT] multilateration data no longer required, disabling mlat client
[2025-04-10 15:25 EDT] fa-mlat-client exited normally
[2025-04-10 15:25 EDT] mlat-client(28329): Exiting on connection loss
[2025-04-10 15:25 EDT] mlat-client(28329): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
On my debian trixi/sid x86_64 & armbian trixie/sid aarch64, I am using tcl-tls-rebuild instead of tcl-tls from Debian repository. May be that makes a difference??? @obj can shed some light.
@CraigWoodThomas
Sometimes I get a NOTICE (see attached screenshot).
It is not frequent, only occasional.
Do you also get such notices?
No, I have never seen a message that MLAT messages were not reaching the server. My Rpi4B is hard wire ethernet connected to an ethernet switch on a network that is typically extremely reliable.
Same for myself. I am also hardwired (PoE) and have not personally seen that one.
WIFI connections are great, until they aren’t. UDP messages are just broadcast by the sender without proof of receipt. It often works, but in high traffic situations whether in the source location or on the internet, they get dropped often because of data collisions between the sender and the receiver. Happens all the time. We used to call it the Unreliable Data Protocol. I’ve been doing this since the late '70’s.
I got into the networking game starting back in 77 working for Xerox Corporation. Grass roots bleeding edge network environment with vampire taps hanging off of 3 meg coax running through the ceilings. The TDR scope was my best friend.
@CraigWoodThomas
@astrodeveloper
@simtra
I see this NOTICE only on Debian-13 trixie/sid x86_64 in Oracle VM on Windows 10 Desktop, connected by eathernet wire to router.
Never seen this NOTICE on RPi with bookworm & trixie/sid, connected on WiFi
Have to wonder if your ethernet connection is dealing with a lot of congestion and contention for the network? Are other computers connected directly to the router?
This Desktop and an OrangePi are wired to the sub-router. This sub-router is connected to main router by wireless. It is TP-Link mesh network. The main router gets feed from Fiber-Optic box, to which incoming fiber-optic cable from ISP is connected.
I have done speed check at this Desktop, and it is around 250~300 Mb/s download & upload.
Sounds clean enough. Some head knocking going on somewhere.
This is my internet service. Declared speed is 500 Mb download/upload, but I measured several times on different days &times, it is 250~300 Mb at the Desktop, which is connected to sub-router
EDIT:
The type of service declared by my ISP is FTTB
I just now Googled to find what FTTB stands for. AI says FTTB means “Fiber To The Building”. The ISP brings fiber up to building’s telecom room, and wired connections from telecom room to individual apartments.
However my ISP, instead of using wires from telecom room to individual apartments, has provided fiber from telecom room to individual apartments as well.
Apparently I do on this particular receiver.
It is connected with Ethernet.
pi@Pi1:~ $ sudo journalctl -u piaware -b | grep NOTICE
Nov 13 15:12:39 Pi1 piaware[11734]: NOTICE from adept server: 15% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 14 23:00:12 Pi1 piaware[11734]: NOTICE from adept server: 48% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 14 23:00:51 Pi1 piaware[11734]: NOTICE from adept server: 34% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:14:17 Pi1 piaware[11734]: NOTICE from adept server: 20% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:18:52 Pi1 piaware[11734]: NOTICE from adept server: 58% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:24:40 Pi1 piaware[11734]: NOTICE from adept server: 45% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:32:43 Pi1 piaware[11734]: NOTICE from adept server: 15% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:40:49 Pi1 piaware[11734]: NOTICE from adept server: 18% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:43:49 Pi1 piaware[11734]: NOTICE from adept server: 53% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:48:15 Pi1 piaware[11734]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:50:22 Pi1 piaware[11734]: NOTICE from adept server: 18% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:50:59 Pi1 piaware[11734]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:53:15 Pi1 piaware[11734]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 21:53:52 Pi1 piaware[11734]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 22:10:44 Pi1 piaware[11734]: NOTICE from adept server: 73% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 16 22:12:37 Pi1 piaware[11734]: NOTICE from adept server: 55% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:16:16 Pi1 piaware[11734]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:20:18 Pi1 piaware[11734]: NOTICE from adept server: 22% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:22:24 Pi1 piaware[11734]: NOTICE from adept server: 15% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:24:20 Pi1 piaware[11734]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:29:23 Pi1 piaware[11734]: NOTICE from adept server: 20% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:36:27 Pi1 piaware[11734]: NOTICE from adept server: 44% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:38:26 Pi1 piaware[11734]: NOTICE from adept server: 36% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 17 12:41:26 Pi1 piaware[11734]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Nov 24 13:51:14 Pi1 piaware[11734]: NOTICE from adept server: 22% of multilateration messages (UDP) are not reaching the server - check your network?
Dec 04 15:28:44 Pi1 piaware[15551]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Dec 12 23:36:22 Pi1 piaware[15551]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Dec 15 02:02:17 Pi1 piaware[15551]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Jan 10 04:03:34 Pi1 piaware[15551]: NOTICE from adept server: 50% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 01 05:25:45 Pi1 piaware[15551]: NOTICE from adept server: 32% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 01 05:26:07 Pi1 piaware[15551]: NOTICE from adept server: 83% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 06 00:04:07 Pi1 piaware[15551]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 21 13:29:28 Pi1 piaware[15551]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 21 16:49:51 Pi1 piaware[15551]: NOTICE from adept server: 68% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 21 17:45:12 Pi1 piaware[15551]: NOTICE from adept server: 52% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 21 18:40:34 Pi1 piaware[15551]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:01:20 Pi1 piaware[15551]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:02:20 Pi1 piaware[15551]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:03:21 Pi1 piaware[15551]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:04:22 Pi1 piaware[15551]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:06:23 Pi1 piaware[15551]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 11:07:23 Pi1 piaware[15551]: NOTICE from adept server: 14% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 12:21:48 Pi1 piaware[15551]: NOTICE from adept server: 10% of multilateration messages (UDP) are not reaching the server - check your network?
Feb 28 12:22:48 Pi1 piaware[15551]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 01 07:25:45 Pi1 piaware[15551]: NOTICE from adept server: 51% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 03 09:58:17 Pi1 piaware[15551]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 03 09:59:03 Pi1 piaware[15551]: NOTICE from adept server: 25% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 03 17:35:09 Pi1 piaware[15551]: NOTICE from adept server: 51% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 08 16:00:07 Pi1 piaware[15551]: NOTICE from adept server: 13% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 08 16:02:08 Pi1 piaware[15551]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 10 18:49:16 Pi1 piaware[15551]: NOTICE from adept server: 15% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 12 16:54:55 Pi1 piaware[15551]: NOTICE from adept server: 21% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 12 16:55:51 Pi1 piaware[15551]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 13 18:26:39 Pi1 piaware[15551]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 23 11:28:48 Pi1 piaware[15551]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 23 11:29:31 Pi1 piaware[15551]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 23 12:04:21 Pi1 piaware[19130]: NOTICE from adept server: 22% of multilateration messages (UDP) are not reaching the server - check your network?
Mar 23 12:21:27 Pi1 piaware[19130]: NOTICE from adept server: 13% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 03 18:39:29 Pi1 piaware[19130]: NOTICE from adept server: 34% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 05 16:07:21 Pi1 piaware[32292]: NOTICE from adept server: 43% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 05 16:45:40 Pi1 piaware[32292]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 11 23:01:10 Pi1 piaware[32292]: NOTICE from adept server: 12% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 11 23:02:10 Pi1 piaware[32292]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 11 23:59:33 Pi1 piaware[32292]: NOTICE from adept server: 12% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 00:02:34 Pi1 piaware[32292]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 00:09:36 Pi1 piaware[32292]: NOTICE from adept server: 14% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:12:58 Pi1 piaware[32292]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:41:09 Pi1 piaware[32292]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:43:23 Pi1 piaware[32292]: NOTICE from adept server: 62% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:44:10 Pi1 piaware[32292]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:49:11 Pi1 piaware[32292]: NOTICE from adept server: 13% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:50:11 Pi1 piaware[32292]: NOTICE from adept server: 30% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:51:12 Pi1 piaware[32292]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 01:57:14 Pi1 piaware[32292]: NOTICE from adept server: 37% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 02:17:15 Pi1 piaware[14372]: NOTICE from adept server: 22% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 02:17:58 Pi1 piaware[14372]: NOTICE from adept server: 33% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:22:11 Pi1 piaware[19200]: NOTICE from adept server: 57% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:23:03 Pi1 piaware[19200]: NOTICE from adept server: 14% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:39:22 Pi1 piaware[22936]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:43:37 Pi1 piaware[22936]: NOTICE from adept server: 64% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:44:23 Pi1 piaware[22936]: NOTICE from adept server: 24% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:53:08 Pi1 piaware[25804]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:58:53 Pi1 piaware[25804]: NOTICE from adept server: 28% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 06:59:50 Pi1 piaware[25804]: NOTICE from adept server: 72% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:07:27 Pi1 piaware[25804]: NOTICE from adept server: 63% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:08:19 Pi1 piaware[25804]: NOTICE from adept server: 49% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:09:39 Pi1 piaware[25804]: NOTICE from adept server: 20% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:10:14 Pi1 piaware[25804]: NOTICE from adept server: 42% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:12:46 Pi1 piaware[25804]: NOTICE from adept server: 33% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:13:56 Pi1 piaware[25804]: NOTICE from adept server: 47% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:14:46 Pi1 piaware[25804]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:15:46 Pi1 piaware[25804]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:17:47 Pi1 piaware[25804]: NOTICE from adept server: 24% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:29:33 Pi1 piaware[25804]: NOTICE from adept server: 98% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:29:52 Pi1 piaware[25804]: NOTICE from adept server: 67% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:41:57 Pi1 piaware[25804]: NOTICE from adept server: 25% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:46:14 Pi1 piaware[25804]: NOTICE from adept server: 40% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:47:08 Pi1 piaware[25804]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:53:33 Pi1 piaware[25804]: NOTICE from adept server: 35% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:54:27 Pi1 piaware[25804]: NOTICE from adept server: 28% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:57:29 Pi1 piaware[25804]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 07:58:35 Pi1 piaware[25804]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:00:57 Pi1 piaware[25804]: NOTICE from adept server: 27% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:06:12 Pi1 piaware[25804]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:06:48 Pi1 piaware[25804]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:08:48 Pi1 piaware[25804]: NOTICE from adept server: 36% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:18:50 Pi1 piaware[17459]: NOTICE from adept server: 46% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:27:24 Pi1 piaware[17459]: NOTICE from adept server: 34% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:29:46 Pi1 piaware[17459]: NOTICE from adept server: 53% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:31:50 Pi1 piaware[17459]: NOTICE from adept server: 55% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:36:39 Pi1 piaware[17459]: NOTICE from adept server: 30% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:37:39 Pi1 piaware[17459]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:38:52 Pi1 piaware[17459]: NOTICE from adept server: 43% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:40:17 Pi1 piaware[17459]: NOTICE from adept server: 60% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:40:40 Pi1 piaware[17459]: NOTICE from adept server: 62% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:41:52 Pi1 piaware[17459]: NOTICE from adept server: 18% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:45:59 Pi1 piaware[17459]: NOTICE from adept server: 49% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:46:43 Pi1 piaware[17459]: NOTICE from adept server: 78% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:47:20 Pi1 piaware[17459]: NOTICE from adept server: 38% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:49:23 Pi1 piaware[17459]: NOTICE from adept server: 28% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:50:22 Pi1 piaware[17459]: NOTICE from adept server: 33% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:51:32 Pi1 piaware[17459]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:52:22 Pi1 piaware[17459]: NOTICE from adept server: 41% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:53:32 Pi1 piaware[17459]: NOTICE from adept server: 55% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:54:23 Pi1 piaware[17459]: NOTICE from adept server: 29% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:55:32 Pi1 piaware[17459]: NOTICE from adept server: 10% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 08:56:23 Pi1 piaware[17459]: NOTICE from adept server: 14% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:24:46 Pi1 piaware[17459]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:25:37 Pi1 piaware[17459]: NOTICE from adept server: 46% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:26:44 Pi1 piaware[17459]: NOTICE from adept server: 33% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:27:38 Pi1 piaware[17459]: NOTICE from adept server: 28% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:28:38 Pi1 piaware[17459]: NOTICE from adept server: 23% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:29:46 Pi1 piaware[17459]: NOTICE from adept server: 36% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 09:30:39 Pi1 piaware[17459]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:03:53 Pi1 piaware[17459]: NOTICE from adept server: 21% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:15:57 Pi1 piaware[17459]: NOTICE from adept server: 10% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:18:58 Pi1 piaware[17459]: NOTICE from adept server: 12% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:22:59 Pi1 piaware[17459]: NOTICE from adept server: 22% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:25:00 Pi1 piaware[17459]: NOTICE from adept server: 12% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:26:00 Pi1 piaware[17459]: NOTICE from adept server: 11% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:36:03 Pi1 piaware[17459]: NOTICE from adept server: 10% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:38:04 Pi1 piaware[17459]: NOTICE from adept server: 16% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:39:04 Pi1 piaware[17459]: NOTICE from adept server: 20% of multilateration messages (UDP) are not reaching the server - check your network?
Apr 12 10:40:04 Pi1 piaware[17459]: NOTICE from adept server: 19% of multilateration messages (UDP) are not reaching the server - check your network?
pi@Pi1:~ $
I’m curious about this Sub-router device. Is this the fiber to copper interface for your network in the apartment?
