Hi everyone
I’ve just got started submitting data to FA but seem to be having some trouble with the MLAT client on my Pi.
On my stats page I have manually set my location, however, the MLAT button is red and says “MLAT disabled/not synchronized/Latitude Longitude not set” and in the list of info at the right I see “Multilateration (MLAT): Supported / Not Enabled”.
In the PiAware log I see the following regarding mlat:
Dec 27 17:40:35 raspberrypi piaware[508]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.225:7164:23928814
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): fa-mlat-client 0.2.10 starting up
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Using UDP transport to 70.42.6.225 port 7164
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Listening for Beast-format results connection on port 30105
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Listening for Extended Basestation-format results connection on port 30106
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Connection to localhost:30005 lost: [Errno 111] Connection refused
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Reconnecting in 0.5 seconds
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Beast-format results connection with ::1:30104: [Errno 111] Connection refused
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Input connected to localhost:30005
Dec 27 17:40:36 raspberrypi piaware[508]: mlat-client(1259): Input format changed to BEAST, 12MHz clock
Dec 27 17:40:37 raspberrypi piaware[508]: Lost connection to adept server at piaware.flightaware.com/1200: server closed connection
Dec 27 17:40:37 raspberrypi piaware[508]: multilateration data no longer required, disabling mlat client
Dec 27 17:40:38 raspberrypi piaware[508]: fa-mlat-client exited normally
Dec 27 17:40:38 raspberrypi piaware[508]: reconnecting in 51 seconds…
Dec 27 17:40:38 raspberrypi piaware[508]: mlat-client(1259): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
Dec 27 17:40:38 raspberrypi piaware[508]: mlat-client(1259): Exiting on connection loss
I’m not sure what to try next! Any would be great. Thanks.
