10/23/2015 14:30:55 lost connection to FlightAware, reconnecting...
10/23/2015 14:30:55 multilateration data no longer required, disabling mlat client
10/23/2015 14:30:55 reconnecting after 60s...
10/23/2015 14:30:56 mlat(1046): Disconnecting from localhost:30005: **Lost connection to multilateration server**, no need for input data
10/23/2015 14:30:56 mlat(1046): Exiting on connection loss
10/23/2015 14:30:56 the system told us that process 1046 exited cleanly
10/23/2015 14:30:56 the system confirmed that process 1046 exited with an exit status of 0
10/23/2015 14:31:55 connecting to FlightAware piaware.flightaware.com/1200
10/23/2015 14:32:45 FlightAware server SSL certificate validated
10/23/2015 14:32:45 encrypted session established with FlightAware
10/23/2015 14:32:45 autoUpdate is not configured in /etc/piaware or by piaware-config
10/23/2015 14:32:45 manualUpdate is not configured in /etc/piaware or by piaware-config
10/23/2015 14:32:45 multilateration support enabled (use piaware-config to disable)
10/23/2015 14:32:45 logged in to FlightAware as user jepolch
10/23/2015 14:32:46 multilateration support enabled (use piaware-config to disable)
10/23/2015 14:32:46 multilateration data requested, enabling mlat client
10/23/2015 14:32:46 Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30104 --results ext_basestation,listen,30106 --udp-transport 70.42.6.197:8818:388947278
10/23/2015 14:32:46 mlat(11076): fa-mlat-client 0.2.4 starting up
10/23/2015 14:32:46 mlat(11076): Using UDP transport to 70.42.6.197:8818
10/23/2015 14:32:46 mlat(11076): Listening for Extended Basestation-format results connection on port 30106
10/23/2015 14:32:46 mlat(11076): Input connected to localhost:30005
10/23/2015 14:32:47 mlat(11076): Beast-format results connection with localhost:30104: connection established
10/23/2015 14:32:51 mlat(11076): Accepted Extended Basestation-format results connection from 192.168.1.5:52870
10/23/2015 14:33:45 server is sending alive messages; we will expect them
10/23/2015 14:35:55 45858 msgs recv'd from dump1090-mutabi (1156 in last 5m); 45412 msgs sent to FlightAware
10/23/2015 14:36:00 lost connection to FlightAware, reconnecting...
10/23/2015 14:36:00 multilateration data no longer required, disabling mlat client
10/23/2015 14:36:00 reconnecting after 60s...
10/23/2015 14:36:00 mlat(11076): Disconnecting from localhost:30005: **Lost connection to multilateration server**, no need for input data
10/23/2015 14:36:01 mlat(11076): Exiting on connection loss
10/23/2015 14:36:01 the system told us that process 11076 exited cleanly
10/23/2015 14:36:01 the system confirmed that process 11076 exited with an exit status of 0
10/23/2015 14:37:00 connecting to FlightAware piaware.flightaware.com/1200
10/23/2015 14:37:01 error during tls handshake: handshake failed: connection reset by peer, will try again soon...
You’re welcome, although I’m not an expert on the subject. I was just passing along some useful info. Can you share the code lines for that graph you posted? I like the added detail. Thanks.
Nope, Time Warner cable. And during those times I lost connection to FA my internet was able to connect to everything else. I was sitting here watching it and I had no other network issues.
No changes on my end, and neither of my receivers are indicating locations from non ADS-B tracks (in either Dump1090 or VRS), though thePiAware log file is indicating MLAT sync with >40 receivers.
Try restarting piaware. The mlat servers are fine at the moment but there may be some residual hiccups if you have not reconnected in the last ~6 hours.
Thanks obj, I sent the restart for PiAware and not my mlat is showing as working. It’s weird because it was saying I was synchronized with 39 receivers before, but they weren’t showing on my graphs or dump1090 screen.
The problem last night was that the result-delivery path was broken for some connections, so you’d be synchronized and generating results but the results would never back it back to piaware.
Yesterday (10/27) the mlat was down on one of my Pi’s most of the day, but the other was up all day. Pretty much identical hardware and software. I restarted Piaware on the one that was down, but it didn’t fix mlat. Finally I rebooted that Pi and mlat started working again. I hate to have to babysit it like this. It used to be rock solid. I guess we can chalk this up to “growing pains”.
