I’m kinda stupid on these things but how would I got about getting MLAT to show up on my VRS without messing up my other settings? I do know my VRS is using 30003 for the feed.
Did you merge the feeds together? So it will show MLAT planes and the rest? Thats what I did to show both on VRS map. Just wanted to see if others did it that way.
That is exactly what I did also. Labeled the receivers ADSB and MLAT. Have you noticed the MLATs quickly change over to the default receiver?
Mine are only showing 5-10 seconds or so.
Which version of VRS are you running ? Here I have 2.1.01579 downloaded from virtualradarserver.co.uk/Preview.aspx , it has a few more options for MLAT
explained in the Change list
Assuming the use of the same dump1090 decoder, what is the rationale for identifying a separate receiver for ADS-B and MLAT? Once I enabled MLAT forwarding on dump1090-m everything comes over the same port (30005 IIRC).
This is not the default if you are using the FA dump1090 or a recent (development) dump1090-mutability; it’s also not suitable if you want to forward port 30005 output elsewhere e.g. other feeders but exclude mlat results.
