Hi guys, what could be wrong here, out of the blue I got:
Got EOF from multilateration client
And the MLAT indicator button is red.
Please copy-paste output of this command:
journalctl -e -u fa-mlat-client
P.S. Dont forget to place [code] above and [/code] below the text you copy-paste from PuTTy terminal
actually we want the piaware output, not the fa-mlat-client output (there is no service for fa-mlat-client, it is started by piaware)
Oops!! Completely forgot this point. Thanks @obj for reminding.
journalctl -e -u piaware
thanks abcd567 and obj. The journalctl replies:
pi@raspberrypi:~ $ journalctl -e -u piaware
Feb 25 07:14:36 raspberrypi sudo[6505]: pam_unix(sudo:session): session closed for user root
Feb 25 07:14:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --inFeb 25 07:14:36 raspberrypi piaware[9838]: got EOF from multilateration client
Feb 25 07:14:36 raspberrypi piaware[9838]: fa-mlat-client exited with SIG SIGILL
Feb 25 07:14:45 raspberrypi piaware[9838]: 2714 msgs recv’d from dump1090-fa (75 in last 5m); 2714 msgs sent to FlightAwFeb 25 07:15:36 raspberrypi sudo[6811]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program
Feb 25 07:15:36 raspberrypi sudo[6811]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 25 07:15:36 raspberrypi sudo[6811]: pam_unix(sudo:session): session closed for user root
Feb 25 07:15:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --inFeb 25 07:15:36 raspberrypi piaware[9838]: got EOF from multilateration client
Feb 25 07:15:36 raspberrypi piaware[9838]: fa-mlat-client exited with SIG SIGILL
Feb 25 07:16:36 raspberrypi sudo[7167]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program
Feb 25 07:16:36 raspberrypi sudo[7167]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 25 07:16:36 raspberrypi sudo[7167]: pam_unix(sudo:session): session closed for user root
Feb 25 07:16:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --inFeb 25 07:16:36 raspberrypi piaware[9838]: got EOF from multilateration client
Feb 25 07:16:36 raspberrypi piaware[9838]: fa-mlat-client exited with SIG SIGILL
Feb 25 07:17:36 raspberrypi sudo[7575]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program
Feb 25 07:17:36 raspberrypi sudo[7575]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 25 07:17:36 raspberrypi sudo[7575]: pam_unix(sudo:session): session closed for user root
Feb 25 07:17:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --inFeb 25 07:17:36 raspberrypi piaware[9838]: got EOF from multilateration client
Feb 25 07:17:36 raspberrypi piaware[9838]: fa-mlat-client exited with SIG SIGILL
Feb 25 07:18:36 raspberrypi sudo[7939]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program
Feb 25 07:18:36 raspberrypi sudo[7939]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 25 07:18:36 raspberrypi sudo[7939]: pam_unix(sudo:session): session closed for user root
Feb 25 07:18:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --inFeb 25 07:18:36 raspberrypi piaware[9838]: got EOF from multilateration client
Feb 25 07:18:36 raspberrypi piaware[9838]: fa-mlat-client exited with SIG SIGILL
lines 973-1001/1001 (END)
Feb 25 07:14:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,3010
Feb 25 07:14:45 raspberrypi piaware[9838]: 2714 msgs recv’d from dump1090-fa (75 in last 5m); 2714 msgs sent to FlightAware
Feb 25 07:15:36 raspberrypi sudo[6811]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Feb 25 07:15:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,3010
Feb 25 07:16:36 raspberrypi sudo[7167]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Feb 25 07:16:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,3010
Feb 25 07:17:36 raspberrypi sudo[7575]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Feb 25 07:17:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,3010
Feb 25 07:18:36 raspberrypi sudo[7939]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Feb 25 07:18:36 raspberrypi piaware[9838]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,3010
Assuming this worked on the same hardware previously, this is probably sdcard corruption.
Ok, thanks for hekping our @obj ! I will run a clean install on a new SD card and see if this does the trick
BR
Guus
sdcard is probably the most likely explanation, but I have seen a couple of reports of similar crashes which makes me a little suspicious. I can’t reproduce it on any hardware I have here. It’s possibly something like an underlying library getting upgraded and breaking binary compatibility - but the package dependencies seem OK. Did you do any installs or upgrades of other software at around the time that it broke?
No, but auto update is ‘allowed’ so maybe it ran some kind of update
Swapped the SD card and reinstalled Piaware, MLAT works like charm again. Thanks for the guidance @obj !
