Friends, I need some help. I had some problems with my old Pi, and had to replace it. I used the same memory card. However, now I’m getting terrible results in my reception, where I can’t get more than , where 15/30 before reached 50/70NM. With that, I would like to check what I can do to try to improve my range or if I am having any other type of problem, either with the antenna or my ADS-B receiver
First of all I would leave dump1090 mutability since that is no longer maintained.
Reinstall dump1090-fa and the latest version of piaware.
Then activate adaptive dynamic gain (check the posts in the forum) and let that run for a day or 2 to see if that improves your reception and range
I returned to dump1090-fa, reinstalled piaware, there was a slight improvement, but still nothing as acceptable. I don’t know if my route is little visited, or if I’m really suffering from some problem that I can’t identify.
Install graphs1090 on your system so you can see visually what is happening to it and where the issues might be.
Maybe the reciever is flooded with strong messages and this might lead to a lower reception range.
By using the program you can identify a number of things and work from there on to improve the reception again.
In general there can be many issues that can cause something like this.
The new pi is using an original RPi power supply? That can be important.
Using an USB extension? That can also cause issues.
Using device 0: Generic RTL2832U OEM
Supported gain values (29) 3.4 43.9 44.5 48.0 49.6
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
I looked at both of your links and your positions by distance is extremely limited which you already know. What antenna are you using? Your gain seems too hot to me. I would drop back 10 points to start with. So many possibilities. How high is your antenna? Is it above the peak of the house if that’s where you are mounted.
My antenna is a Jetvision SCO-1090-GPS with a 10 meter 50 ohm cable
and is located high above my house with a clear view of the sky, although I live in a valley, and have received receptions at 80-100nm
Looking at your test results and the graphs my suspicion would be that your dongle is dying.
The limited set of gain results is strange as Wiedehopf stated.
Do you have a spare dongle to test with?
A max gain of 58.6 dB is normal for a RTL-SDR v3 dongle as being the value.
This equals AGC or the 49.6dB that is seen on a FA Pro stick dongle.
They show that you are receiving very low signal levels, even though you have a high gain setting. Given the strange gain value response from your dongle, I would suspect that the dongle is failing. It could however be an antenna or coax fault.
I ordered a new dongle, which should take a few days to arrive. As soon as it is in hand, I will carry out further tests. I thank everyone for the help.
After exchanging the dongle for one from FlightAware, the problem was resolved and we once again had good statistics. I appreciate everyone’s help in detecting the problem.
