I recently installed the ‘ADS-B Project’ with dump1090-fa on my Raspberry Pi 1B (Raspbian Stretch) with an antenna I bought from AliExpress. I had a plane passing over about 15 miles away and the antenna did not seem to pick it up whatsoever. I have ran the ‘RTL Test’ and here are the results:
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
usb_claim_interface error -6
Failed to open rtlsdr device #0.
If anyone else has any idea on what I can do to resolve this, that would be great. Am I missing any drivers or do I have a faulty antenna? Let me know please.
PiAware master process (piaware) is running with pid 433.
PiAware ADS-B client (faup1090) is running with pid 661.
PiAware ADS-B UAT client (faup978) is not running.
Local ADS-B receiver (dump1090-fa) is running with pid 310.
dump1090-fa (pid 310) is listening for connections on port 30005.
no program appears to be listening for connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ‘couldn’t open socket: connection refused’
It depends - which antenna did you purchase from AliExpress? Some are much better than others and without knowing, tough to answer other than maybe telling you to test them side by side the best you can. Location, noise, antenna height, etc are all determining factors to consider. IE a stock antenna on your roof will more than likely perform better than the best antenna sitting on your desk, so much to consider to get to a black and white answer.
Place your magnetic base antenna on a metallic plate or food can, and you will notice good improvement. In addition if the plate or can is made of iron/steel, the magnetic base will cling to it and hold the antenna upright.
Is ‘ADS-B Project’ somebody’s image or set of instructions?
Suggest you start with the FA PiAware image - it will work ‘out of the box’. You can then start to play and customize once you are confident everything is working.
Yes maybe.
But the main connect of this discussion board is to Flightaware. We should be at least glad that they do not delete threads related to other systems. I’ve seen this several times in other boards (not flight related)
Yeah, I’ve installed this system as you can install FR24 feed on it as well, and as I’m quite a ‘new’ person to this, I found it to be a rather easy install process. Would it be possible to install the FR24 feed on top of the FA image then?
Still a bit unclear what this system is but the suggestion from @geckoVN to start with the Flightaware image is by far the easiest, most basic and it should just work. If it does not work then it is the easiest to debug and the easiest to get support on this discussion board.
Then, once you are feeding Flightaware there are instructions on this board to add feeds to all the other aggregators.
