Issues with recreating my PiAware Site
OK, it was my fault to begin with by not backing up my SD before it crashed a few days ago (Ver 6.0 recently updated) I have had to rebuild from the beginning with a download of Ver 6.1. I captured the feeder_id from my status page and added it to the piaware-config.txt file. The system started ok and SkyAware is working. SSH works fine so the IP address is exactly the same as before. Below is the output from -status. It indicates that I’m not connected to Flightaware and I don’t have a feeder ID yet.
It’s been well over 30 min with no indication that any connection has been made yet.
I may have overlooked something so I would really appreciate any suggestions/recommendations.
Thanks for any assistance,
Dave Firestone
pi@piaware:~ $ sudo piaware-status
PiAware master process (piaware) is running with pid 521.
PiAware ADS-B client (faup1090) is running with pid 599.
Local ADS-B receiver (dump1090-fa) is running with pid 518.
dump1090-fa (pid 518) is listening for ES connections on port 30005.
piaware is NOT connected to FlightAware.
You don’t have a feeder ID yet.
sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Where xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx is the 32- digit feeder id (Unique Identifier) you copied from your FA stats page.
Thanks so much…that fixed part of the problem. Actually, as a result of your suggestion I discovered that my piaware-config.txt file had “feeder_id” vice “feeder-id”.
Per the last -status I still have no connection to FlightAware.
Thanks again for your quick response and input!!!
PiAware master process (piaware) is running with pid 721.
PiAware ADS-B client (faup1090) is running with pid 739.
Your feeder ID is xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx (configured at /boot/piaware-config.txt:97)
Seems some characters are missed out in xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx while copy-pasting it from your FA my adsb site to file /boot/piaware-config.txt. Again copy-paste it, making sure all 32 characters are copied and pasted. You can count the numbers of characters to make sure. There are 8-4-4-4-12 characters (total 32).
After copy paste and saving piaware-config.txt, restart piaware.
Thanks! I checked and confirmed the ID and then went through the copy/paste process again anyway. Character count is ok and resultant input to the config file added it in again with the comment # updated by fa_piaware_config (I’d show the ID here but security issues…)
Much appreciated…
(1) Did you restart piaware or rebooted Pi after re-copy-pasting feeder-id?
(2) What is output of this command
ping -c 3 google.com
You may have gotten me on that one:-) I did the restart first and then later did a reboot via the shutdown and power up route.
Here is the result of the ping. I clearly need to check my configuration on that. It appears DNS my not be working as I have it configured. Will spend some time on that after dinner.
pi@piaware:~ $ ping -c 3 google.com
ping: google.com: Temporary failure in name resolution
pi@piaware:~ $ ping -c 3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 192.168.1.160 icmp_seq=1 Destination Host Unreachable
From 192.168.1.160 icmp_seq=2 Destination Host Unreachable
From 192.168.1.160 icmp_seq=3 Destination Host Unreachable
— 8.8.8.8 ping statistics —
3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 44ms
pipe 2
Here is the appropriate lines from the config file:
wireless-address 192.168.1.160
wireless-netmask 255.255.255.0
wireless-broadcast 192.168.1.255
wireless-gateway 192.168.1.254
wireless-nameservers 8.8.8.8 8.8.4.4
I’ve still got work to do:-) Thanks again…
I changed the gateway to .1 vice .254 and got a connection to FlightAware. Am not sure where I found .254 but things appear to be working better. Will watch it for awhile and see how the data collection goes.
Thanks for your help and encouragement!!
Congratulations!
Thanks for the hand-holding!!!
For the benefit of anyone coming across this thread later, another place to look at for connection issues like this is /var/log/piaware.log (that’ll tell you why piaware can’t connect to the FlightAware servers)
(also, DHCP is usually what you want in the typical home network environment, static configs are uncommon)
OBJ, thanks for closing the loop on that. You and abcd567 have been very helpful. With 778 days of continuous operation of the great Piaware software, I regrettably didn’t stay current with the knowledge and skills.
I appreciate your DHCP comment. I chose a static configuration because I have other programs (PuTTY and VirtualRadar) already set up with that address.
Now, tonight when the number of aircraft flying drops off, I have to bring down the tracker and backup the SD so I don’t have to go through this next time the SD gets corrupted. Lesson learned :slight_smile:
Thanks again!!
Have a look here, a solution to backup over net network… I think last post is what is required.
I’ll check that out. Thanks!!
