Intermittent dump1090 (is)/(is NOT) producing data on localhost:30005
If dongle is OK then other possibility is intermittent connection between antenna & dongle. This can br due to coax connector is broken or the coax itself is broken from inside.
If you have an indoor antenna like the one shown in the post linked below, you can disconnect your regular antenna’s coax from the ProStick and connect this indoor mag mount antenna and run your setup for few days to see if intermittent behaviour stays or is gone
