Hi,
am going through this problem. Can’t install piaware and dump1090 fa. Does anyone know the solution?I mean how can I change “stable” to jessie?
What this command outputs?
cat /etc/apt/sources.list.d/piaware.listIn my case (Jessie and Stretch both) it says:
pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/piaware.list
deb http://flightaware.com/adsb/piaware/files/packages jessie piaware -
You seem to have downloaded 3 copies of piaware-repository_3.5.3_all.deb. If you give following command, you will see all three
pi@raspberrypi:~ $ ls
piaware-repository_3.5.3_all.deb.1
piaware-repository_3.5.3_all.deb.2 -
Delete all the above 3 copies
pi@raspberrypi:~ $ sudo rm piaware-repository* -
Give following command. It will remove the file
piaware.listand any other files installed by piaware-repository_3.5.3_all.deb.
pi@raspberrypi:~ $ sudo dpkg --purge piaware-repository
(Reading database ... 39458 files and directories currently installed.
Removing piaware-repository (3.5.3) ...
Purging configuration files for piaware-repository (3.5.3) ...Check file
piaware.listhas been removed
cat: /etc/apt/sources.list.d/piaware.list: No such file or directory -
Reboot
pi@raspberrypi:~ $ sudo reboot -
Now start fresh
pi@raspberrypi:~ $ wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.5.3_all.debpi@raspberrypi:~ $ sudo dpkg -i piaware-repository_3.5.3_all.debpi@raspberrypi:~ $ sudo apt-get update
I wrote
sudo nano /etc/apt/apt.conf.d/10defaultRelease
then changed “STABLE” to “jessie”,saved it.
It’s working now.
But can I delete repository 1 and 2 and keep only one?
Yes, if you mean deleting:
and keeping only:
yes,I deleted all,started fresh,but plane is not detected,what to do?
Do you see SkyView map at ip-of-pi/dump1090-fa/ ?
what is the output of
sudo systemctl status piaware -l
test your dongle is detected
sudo apt-get install rtl-sdr
sudo rtl_test -t
It’s working but no plane detected…piaware webpage is opening too
Did you test your dongle? see my above post.
No supported tuner found !!!
test your dongle:
sudo rtl_test -t
tighten the cable connector and got this,planes are detected now
for add-on packages restart,update of dump1090 and piaware isn’t possible from the fa status page,right?
I saw it when I wrote the sd-card image.
WRONG
Give these commands, then check status page:
perfect…all working ok now ![]()
Try this:
sudo lighty-enable-mod dump1090
sudo systemctl force-reload lighttpd
sudo reboot
not working ![]()
The Piaware STATUS page at IP-OF-PI is available ONLY in Piaware SD Card image.
You have Raspbian image + Piaware add-on. You wont get it.
Try to install with this
sudo apt-get install piaware-web
Hope it works for you.
Good luck.
