How to make piaware start ONLY manually?
Hello,
I have piaware working on my Pi 3 unit, but I want to have piaware/dunp1090 and the webserver ONLY start manually - right now everything starts on boot.
How can I make piawawre only run when I manually tell it to? I don’t want a webserver, etc running at boot.
I tried removing piaware from rc-update, but that didn’t seem to help, and apparently dump1090-fa still runs even when I manually stop the piaware service. There is no dump1090 in /etc/init.d/ etither!
Thanks!
What image are you starting from and how did you install piaware and dump1090-fa?
Note that neither dump1090-fa nor piaware run a webserver.
Jessie image from main raspberry pi home page, I did the 3.1.0 repository as per:
flightaware.com/adsb/piaware/install
What I’m looking to have is manual control on when I start and stop piaware/dump1090/webserver (or whatever is answering on :8080), as I use this Pi on offline networks, I want to use the DVB dongle to receive FM radio, etc using GQRX, etc.
Thanks!
In that setup piaware and dump1090-fa are started by systemd services. You can use systemctl to manage them. If you also want to stop the webserver, that is lighttpd.
Sorry to jump into an old thread, but recently noted following, and I dont understand the advantage of this:
Contrary to previous versions, the latest version of Flightradar24 feeder is disabled by default when installed by .deb package, and does not start automatically on boots, unless the user explicitly enables it by following command
sudo systemctl enable fr24feed
