My Hourly Positions Stats Fallen off cliff.
From about Midday on 29/01/2023, my stats show a big decrease in positions reported back.
Gone from 100,000 to 45,000 at peak. But still the same amount of aircraft.
Nothing has changed in equipment side, but my skyaware software updated from 7.2 to 8.2.
You could check your logs, are the numbers there decreased as well ? I sometimes have the same, usually it is because of a different back-end server that receives the reports. Some servers request an increased reporting frequency and others don’t.
Not much you can do about that. Due to the number of aircraft being equal I don’t think you have issues with the setup on your end.
[2023-01-29 09:37 GMT] 183989 msgs recv’d from dump1090-fa (3173 in last 5m); 183724 msgs sent to FlightAware
[2023-01-29 09:42 GMT] 187210 msgs recv’d from dump1090-fa (3221 in last 5m); 186945 msgs sent to FlightAware
[2023-01-29 09:47 GMT] 190412 msgs recv’d from dump1090-fa (3202 in last 5m); 190147 msgs sent to FlightAware
[2023-01-29 09:52 GMT] mlat-client(739): Server status: synchronized with 549 nearby receivers
[2023-01-29 09:52 GMT] mlat-client(739): Server: 0.1 kB/s from server 0.0kB/s TCP to server 2.4kB/s UDP to server
[2023-01-29 09:52 GMT] mlat-client(739): Aircraft: 14 of 22 Mode S, 68 of 102 ADS-B used
[2023-01-29 09:52 GMT] mlat-client(739): Receiver status: connected
[2023-01-29 09:52 GMT] mlat-client(739): Receiver: 1366.2 msg/s received 240.4 msg/s processed (18%)
[2023-01-29 09:52 GMT] 193484 msgs recv’d from dump1090-fa (3072 in last 5m); 193219 msgs sent to FlightAware
[2023-01-29 09:57 GMT] 196752 msgs recv’d from dump1090-fa (3268 in last 5m); 196487 msgs sent to FlightAware
[2023-01-29 10:07 GMT] mlat-client(739): Receiver status: connected
[2023-01-29 10:07 GMT] mlat-client(739): Server status: synchronized with 563 nearby receivers
[2023-01-29 10:07 GMT] mlat-client(739): Results: 92.9 positions/minute
[2023-01-29 10:12 GMT] 207029 msgs recv’d from dump1090-fa (3385 in last 5m); 206764 msgs sent to FlightAware
[2023-01-29 10:17 GMT] 210315 msgs recv’d from dump1090-fa (3286 in last 5m); 210050 msgs sent to FlightAware
[2023-01-29 10:22 GMT] mlat-client(739): Receiver: 1418.2 msg/s received 242.8 msg/s processed (17%)
[2023-01-29 10:22 GMT] mlat-client(739): Server: 0.2 kB/s from server 0.0kB/s TCP to server 2.5kB/s UDP to server
[2023-01-29 10:22 GMT] mlat-client(739): Results: 69.3 positions/minute
[2023-01-29 10:32 GMT] 220733 msgs recv’d from dump1090-fa (3409 in last 5m); 220468 msgs sent to FlightAware
[2023-01-29 10:37 GMT] mlat-client(739): Server: 0.2 kB/s from server 0.0kB/s TCP to server 2.7kB/s UDP to server
[2023-01-29 10:37 GMT] mlat-client(739): Server status: synchronized with 553 nearby receivers
[2023-01-29 10:37 GMT] mlat-client(739): Aircraft: 19 of 29 Mode S, 68 of 99 ADS-B used
[2023-01-29 10:37 GMT] mlat-client(739): Results: 79.4 positions/minute
[2023-01-29 10:37 GMT] mlat-client(739): Receiver: 1409.2 msg/s received 259.4 msg/s processed (18%)
[2023-01-29 10:37 GMT] 224199 msgs recv’d from dump1090-fa (3466 in last 5m); 223934 msgs sent to FlightAware
[2023-01-29 10:42 GMT] 227782 msgs recv’d from dump1090-fa (3583 in last 5m); 227517 msgs sent to FlightAware
[2023-01-29 10:52 GMT] mlat-client(739): Server: 0.2 kB/s from server 0.0kB/s TCP to server 2.6kB/s UDP to server
[2023-01-29 10:52 GMT] mlat-client(739): Server status: synchronized with 555 nearby receivers
[2023-01-29 10:52 GMT] mlat-client(739): Aircraft: 15 of 27 Mode S, 70 of 116 ADS-B used
[2023-01-29 10:52 GMT] mlat-client(739): Results: 79.0 positions/minute
[2023-01-29 10:52 GMT] 235505 msgs recv’d from dump1090-fa (4072 in last 5m); 235240 msgs sent to FlightAware
[2023-01-29 10:57 GMT] 239351 msgs recv’d from dump1090-fa (3846 in last 5m); 239086 msgs sent to FlightAware
[2023-01-29 11:02 GMT] 243141 msgs recv’d from dump1090-fa (3790 in last 5m); 242876 msgs sent to FlightAware
[2023-01-29 11:07 GMT] mlat-client(739): Server status: synchronized with 557 nearby receivers
[2023-01-29 11:07 GMT] mlat-client(739): Receiver: 1561.6 msg/s received 243.4 msg/s processed (16%)
[2023-01-29 11:07 GMT] mlat-client(739): Receiver status: connected
[2023-01-29 11:17 GMT] 253822 msgs recv’d from dump1090-fa (3125 in last 5m); 253557 msgs sent to FlightAware
[2023-01-29 11:22 GMT] mlat-client(739): Results: 38.3 positions/minute
[2023-01-29 11:22 GMT] 256837 msgs recv’d from dump1090-fa (3015 in last 5m); 256572 msgs sent to FlightAware
As I stated earlier, you have had an increased reporting server. You are now returning to the stats prior to January 1st.
There’s nothing wrong with your setup but the backend server where you are reporting to is changed. There is a cluster of servers where you report to so that can change over time.
