It would be great to have a home assistant component so that one can have a card in home assistant with current status of Piaware. Ie is feed up, links are up and whatever.
For FR24 there is custom sensors created from json. Maybe this is possible?
FlightRadar24 as an Add-On? - #2 by exxamalte - Home Assistant OS - Home Assistant Community ?
Here’s a page I worked up in a few minutes.
The card code is as follows:
type: custom:stack-in-card
mode: vertical
cards:
- type: markdown
content: |
<center>
[SkyAware](http://192.168.nnn.nnn/skyaware/)
[FlightAware Site Page]({{ states('sensor.piaware_site_url') }})
Serial Number: {{ states('sensor.piaware_serial_number') }}
Software Version: {{ states('sensor.piaware_dump1090_version') }}
- type: entities
entities:
- entity: sensor.piaware_temperature
- entity: sensor.piaware_cpu_load
- type: sensor
entity: sensor.piaware_nearby_aircraft
icon: mdi:airplane-search
graph: line
hours_to_show: 72```
Terrorr
November 14, 2022, 4:56pm
4
Hello,
could You tell how did You get sensor.piaware_nearby_aircraft ?
It is also possible to get how many aircraft was spotted today ?
Terrorr
January 13, 2023, 12:33pm
6
Thanks !
In flightaware unit right path is:
command: “curl -s http://192.168.0.80/dump1090-fa/data/aircraft.json | grep hex | wc -l”
Working fine
