Just experimenting. Trying to see if I can install the graphs onto my Radarcape. First thing I thought was to install lighttpd, which is probably not on it. Sort of successful install but below is the bottom lines of the install
Packages successfully installed!
Overwriting /etc/collectd/collectd.conf, the old file has been moved to /etc/collectd/collectd.conf.graphs1090
Non-standard configuration detected, you need to change the data URL in /etc/collectd/collectd.conf!
Some features are not available on jessie!
Created symlink from /etc/systemd/system/default.target.wants/graphs1090.service to /lib/systemd/system/graphs1090.service.
All done! Graphs available at http://10.168.0.6/graphs1090
It may take up to 10 minutes until the first data is displayed
Now I have all the lines if someone needs them. The graphs did not display but any further suggestions. There are obviously some more things required.
