Well I have one now, getting use to what it does etc. I am interested to see if I can install 1090 mutability on it. I have found bits an pieces of what you might have to do, but nothing all in the one place or some nobo ways of what to do.
I don’t want to break anything but I would imagine … Is it the fact that you would install what ever version you intend to use onto the SD card already in place. Now I think it is a 4 gb size. You would set up your ADSB Receiver directory and go from there??? Now I use Joe’s streams etc, I know I have to install beastsplitter to make it work and there is a good post about doing that. Could it be as simple as that, installing the ADSB directory onto the sd card , set up the beastsplitter to read the right thing. I am not sure how you would go in regards to gain etc. I am not sure how the Radarcape function in that area, being quite different to the DVB sticks that are used. Now I know you can add a DVB stick into the external USB port and some how run it via there, using the features of the stick but I would like to be using the features of the Radacape to run 1090 mutability
So if someone has successfully installed mutability onto a Radarcape, please share for a good follower of what to do with scripts, to get something working. ![]()
