Graphs1090 graphs not loading after switching SD cards
I was running Graphs1090 with Flightaware, FR24, Radarbox and adsbexchange but recently had to switch SD cards because the old card was dying. I reinstalled Graphs1090 on the newly built Raspberry Pi and followed the instructions of copying the old graphs files in ```
/var/lib/collectd/rrd/ from the old memory card to the new one. However, once I did that none of my graphs would load. I checked the logs and was getting this message
rrdtool plugin: rrd_update_r (/run/collectd/localhost/dump1090-localhost/dump1090_cpu-demod.rrd) failed: reached EOF while loading header rrd->ds_def
Any help with this would be appreciated. Thanks
Probably 32bit → 64bit.
You’d have to export on a 32bit system to xml, then import from xml on a 64bit system.
