I’ve followed instruction on readme previously and sucessfully backed up and restored my graphs however, had a spare pi4 laying around and wanted to move across to it.
I’m running Raspberry Pi o/s 64bit where previously i was on Raspbian.
I’ve run the below before carrying out the backup process
sudo /usr/share/graphs1090/rrd-dump.sh /var/lib/collectd/rrd/localhost
The issue i’m having is when it comes to restoring I get the following error:
$ cd /var/lib/collectd/rrd
$ sudo cp /tmp/rrd.tar /var/lib/collectd/rrd/
$ sudo systemctl stop collectd
$ sudo tar xf rrd.tar
$ sudo systemctl restart collectd graphs1090
Job for collectd.service failed because the control process exited with error code.
See "systemctl status collectd.service" and "journalctl -xe" for details.
From systemctl status collectd.service
collectd[20917]: gzip: /run/collectd/localhost/interface-wlan0/if_errors.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-wlan0/if_dropped.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-wlan0/if_packets.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-eth0/if_octets.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-eth0/if_errors.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-eth0/if_dropped.rrd.gz already exists; not overwritten
collectd[20917]: gzip: /run/collectd/localhost/interface-eth0/if_packets.rrd.gz already exists; not overwritten
systemd[1]: collectd.service: Control process exited, code=exited, status=1/FAILURE
systemd[1]: collectd.service: Failed with result ‘exit-code’.
systemd[1]: Failed to start Statistics collection and monitoring daemon.
From journalctl -xe
– The process’ exit code is ‘exited’ and its exit status is 1.
collectd[22294]: gzip: /run/collectd/localhost/disk-mmcblk0/disk_ops.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/disk-mmcblk0/disk_merged.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/disk-mmcblk0/disk_time.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/disk-mmcblk0/disk_io_time.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/disk-mmcblk0/disk_octets.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/system_stats/memory-buffers.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/system_stats/memory-used.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/system_stats/memory-free.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/system_stats/memory-cached.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/table-localhost/gauge-cpu_temp.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_aircraft-recent.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_tracks-single_message.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_gps-recent.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_mlat-recent.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_cpu-background.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-NaN.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-local_accepted.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_range-minimum.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_cpu-demod.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-remote_accepted.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-noise.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-signal.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_cpu-reader.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-remote_accepted_1.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_range-quart3.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-quart3.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-peak_signal.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_range-median.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-median.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_tracks-all.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-strong_signals.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-positions.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-remote_accepted_0.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-local_accepted_1.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_messages-local_accepted_0.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_range-quart1.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-quart1.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_range-max_range.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_dbfs-min_signal.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/dump1090-localhost/dump1090_tisb-recent.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/df-root/df_complex-free.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/df-root/df_complex-used.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/df-root/df_complex-reserved.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-wlan0/if_octets.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-wlan0/if_errors.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-wlan0/if_dropped.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-wlan0/if_packets.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-eth0/if_octets.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-eth0/if_errors.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-eth0/if_dropped.rrd.gz already exists; not overwritten
collectd[22294]: gzip: /run/collectd/localhost/interface-eth0/if_packets.rrd.gz already exists; not overwritten
Does anyone know how i can fix this or am i all out of luck and have to reset and start afresh?
