Collectd
Hi all
New system running smooth but collectd is not heres error
Ubuntu 20.04.4 LTS
graphs1090
tar1090
airspy_adsb
readsb (set net-only)
rpimonitor
pc 64bit
tried ubuntu 20 few options here
Restoring graphs1090 error on different architecture
Reading package lists… Done
Building dependency tree
The following NEW packages will be installed
collectd
0 to upgrade, 1 to newly install, 0 to remove and 0 not to upgrade.
Need to get 0 B/21.2 kB of archives.
After this operation, 204 kB of additional disk space will be used.
Selecting previously unselected package collectd.
(Reading database … 229505 files and directories currently installed.)
Preparing to unpack …/collectd_5.9.2.g-1ubuntu5_amd64.deb …
Unpacking collectd (5.9.2.g-1ubuntu5) …
Setting up collectd (5.9.2.g-1ubuntu5) …
Job for collectd.service failed because the control process exited with error code.
See “systemctl status collectd.service” and “journalctl -xe” for details.
invoke-rc.d: initscript collectd, action “restart” failed.
● collectd.service - Statistics collection and monitoring daemon
Loaded: loaded (/lib/systemd/system/collectd.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/collectd.service.d
└─malarky.conf
Active: activating (auto-restart) (Result: exit-code) since Mon 2022-03-14 10:24:15 GMT; 4ms ago
Docs: man:collectd(1)
man:collectd.conf(5)
https://collectd.org
Process: 90238 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
Process: 90239 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code=exited, status=0/SUCCESS)
Process: 90252 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
Process: 90253 ExecStart=/usr/sbin/collectd (code=exited, status=1/FAILURE)
Process: 90254 ExecStopPost=/bin/bash /usr/share/graphs1090/writeback.sh (code=exited, status=0/SUCCESS)
Main PID: 90253 (code=exited, status=1/FAILURE)
dpkg: error processing package collectd (–configure):
installed collectd package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
collectd
E: Sub-process /usr/bin/dpkg returned an error code (1)
latest del / reinstall
All done! Graphs available at http://192.168.0.12/graphs1090
It may take up to 10 minutes until the first data is displayed
john@john-H81M-S2H:~$ systemctl status collectd.service
└─malarky.conf
Active: activating (auto-restart) (Result: exit-code) since Mon 2022-03-14 14:43:45 GMT; 6s ago
Process: 218223 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
Process: 218224 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code=exited, status=0/SUCCESS)
Process: 218237 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
Process: 218238 ExecStart=/usr/sbin/collectd (code=exited, status=1/FAILURE)
Process: 218239 ExecStopPost=/bin/bash /usr/share/graphs1090/writeback.sh (code=exited, status=0/SUCCESS)
Main PID: 218238 (code=exited, status=1/FAILURE)
What did the suggestion say? Please run these two commands (put sudo in front)
And please do us a favor formatting your logs posted here. Damn hard to read.
For this mark the text and press the “preformatting” icon on the toolbar:
My graphs1090 are nill
john@john-H81M-S2H:~$ sudo apt-get -y install collectd
Reading package lists... Done
collectd is already the newest version (5.9.2.g-1ubuntu5).
0 to upgrade, 0 to newly install, 0 to remove and 3 not to upgrade.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up collectd (5.9.2.g-1ubuntu5) ...
See "systemctl status collectd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript collectd, action "restart" failed.
             └─malarky.conf
     Active: activating (auto-restart) (Result: exit-code) since Mon 2022-03-14 14:57:02 GMT; 4ms ago
    Process: 226006 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
    Process: 226007 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code=exited, status=0/SUCCESS)
    Process: 226020 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
    Process: 226021 ExecStart=/usr/sbin/collectd (code=exited, status=1/FAILURE)
    Process: 226022 ExecStopPost=/bin/bash /usr/share/graphs1090/writeback.sh (code=exited, status=0/SUCCESS)
   Main PID: 226021 (code=exited, status=1/FAILURE)
dpkg: error processing package collectd (--configure):
 collectd
john@john-H81M-S2H:~$ sudo journalctl -xe
[sudo] password for john:
Mar 14 16:36:58 john-H81M-S2H collectd[273930]: Found a configuration for the `python' plugin, but the plugin isn't loaded or didn't register a conf>
Mar 14 16:36:58 john-H81M-S2H collectd[273930]: Plugin python failed to handle option ModulePath, return code: -1
Mar 14 16:36:58 john-H81M-S2H systemd[1]: collectd.service: Main process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- An ExecStart= process belonging to unit collectd.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Mar 14 16:36:58 john-H81M-S2H collectd[273931]: writing DB from /run/collectd to disk
Mar 14 16:36:58 john-H81M-S2H systemd[1]: collectd.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit collectd.service has entered the 'failed' state with result 'exit-code'.
Mar 14 16:36:58 john-H81M-S2H systemd[1]: Failed to start Statistics collection and monitoring daemon.
-- Subject: A start job for unit collectd.service has failed
-- A start job for unit collectd.service has finished with a failure.
-- The job identifier is 222393 and the job result is failed.
Mar 14 16:37:06 john-H81M-S2H sudo[273945]:     john : TTY=pts/0 ; PWD=/home/john ; USER=root ; COMMAND=/usr/bin/journalctl -xe
Mar 14 16:37:06 john-H81M-S2H sudo[273945]: pam_unix(sudo:session): session opened for user root by john(uid=0)
lines 2663-2689/2689 (END)
https://github.com/wiedehopf/graphs1090#ubuntu-20-fixes-symptom-collectd-errors-out-on-startup
Hi wiedehopf
i had already found that repair post (Ubuntu 20 fixes )
but nothing happend
i redone all today and same result
i can restart full install
that should do it
many thanks
john@john-H81M-S2H:~$ sudo apt update
Hit:1 http://gb.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://gb.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://gb.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:5 http://giteduberger.fr rpimonitor/ InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Get:4 https://raw.githubusercontent.com/abcd567a/ubuntu/master ./ InRelease [2,1                   15 B]
Fetched 2,115 B in 0s (4,665 B/s)
All packages are up-to-date.
john@john-H81M-S2H:~$ sudo apt dist-upgrade
Calculating upgrade... Done
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
Do you want to continue? [Y/n]
Job for collectd.service failed because the control process exited with error co                   de.
     Loaded: loaded (/lib/systemd/system/collectd.service; enabled; vendor prese                   t: enabled)
             └─malarky.conf
     Active: activating (auto-restart) (Result: exit-code) since Tue 2022-03-15                    11:04:56 GMT; 4ms ago
    Process: 5195 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCC                   ESS)
    Process: 5196 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code                   =exited, status=0/SUCCESS)
    Process: 5209 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCC                   ESS)
    Process: 5210 ExecStart=/usr/sbin/collectd (code=exited, status=1/FAILURE)
    Process: 5211 ExecStopPost=/bin/bash /usr/share/graphs1090/writeback.sh (cod                   e=exited, status=0/SUCCESS)
   Main PID: 5210 (code=exited, status=1/FAILURE)
 installed collectd package post-installation script subprocess returned error e                   xit status 1
 collectd
john@john-H81M-S2H:~$ echo "LD_PRELOAD=/usr/lib/python3.8/config-3.8-x86_64-linux-gnu/libpython3.8.so" | sudo tee -a /etc/default/collectd
john@john-H81M-S2H:~$ sudo echo "LD_PRELOAD=/usr/lib/python3.8/config-3.8-x86_64-linux-gnu/libpython3.8.so" | sudo tee -a /etc/default/collectd
john@john-H81M-S2H:~$ sudo systemctl restart collectd
use Ubuntu 21 or whatever …
I’m chicken so gone for Debian 11 :grinning:
Hi again
well right confused now
installed debain 11
all and working up untill a reboot just now
im now getting backend again not working
no graphs
it did display some time but failed after reboot
so weird
root@server:/home/john# systemctl status collectd.service
             └─malarky.conf
     Active: active (running) since Tue 2022-03-15 21:29:30 GMT; 5min ago
    Process: 599 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
    Process: 614 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code=exited, status=0/SUCCESS)
    Process: 725 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
   Main PID: 726 (collectd)
      Tasks: 12 (limit: 19028)
     Memory: 59.5M
        CPU: 680ms
     CGroup: /system.slice/collectd.service
             └─726 /usr/sbin/collectd
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "irq" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "load" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "memory" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "processes" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "rrdtool" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "swap" successfully loaded.
Mar 15 21:29:30 server collectd[726]: plugin_load: plugin "users" successfully loaded.
Mar 15 21:29:30 server collectd[726]: Systemd detected, trying to signal readiness.
Mar 15 21:29:30 server systemd[1]: Started Statistics collection and monitoring daemon.
Mar 15 21:29:30 server collectd[726]: Initialization complete, entering read-loop.
root@server:/home/john# journalctl -xe
Mar 15 21:36:53 server airspy_adsb[496]: Push client connected to 127.0.0.1:30004 (beast)
Mar 15 21:36:53 server airspy_adsb[496]: Push client disconnected from 127.0.0.1:30004 (beast)
Mar 15 21:37:04 server systemd[1]: readsb.service: Scheduled restart job, restart counter is at 15.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ Automatic restarting of the unit readsb.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Mar 15 21:37:04 server systemd[1]: Stopped readsb ADS-B receiver.
░░ Subject: A stop job for unit readsb.service has finished
░░ A stop job for unit readsb.service has finished.
░░ The job identifier is 2599 and the job result is done.
Mar 15 21:37:04 server systemd[1]: Started readsb ADS-B receiver.
░░ Subject: A start job for unit readsb.service has finished successfully
░░ A start job for unit readsb.service has finished successfully.
░░ The job identifier is 2599.
Mar 15 21:37:04 server readsb[5348]: readsb: Too many arguments
Mar 15 21:37:04 server readsb[5348]: Try `readsb --help' or `readsb --usage' for more information.
Mar 15 21:37:04 server readsb[5348]: Command line used:
Mar 15 21:37:04 server readsb[5348]: /usr/bin/readsb --net-only --write-json-every 1 --lat 52.24748 --max-range 500 --net --net-heartbeat 60 --net-ro-size 1>
Mar 15 21:37:04 server systemd[1]: readsb.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit readsb.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Mar 15 21:37:04 server systemd[1]: readsb.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit readsb.service has entered the 'failed' state with result 'exit-code'.
Mar 15 21:37:06 server airspy_adsb[496]: Push client connected to 127.0.0.1:30004 (beast)
Mar 15 21:37:06 server airspy_adsb[496]: Push client disconnected from 127.0.0.1:30004 (beast)
It is telling you there is a problem with your command line. Looks to me that you are missing a longitude.
Ive just noticed i got 2 conf
readsb has lat / lon
 readsb.airspyconf  has not got lat / lon ??
that cannot be right can it
deleted readsb.airspyconf
surprising what a pair of – can do
Thankyou for the nudge
blind looking to hard double checking still dont work
heres all sorted
root@server:/etc/default# systemctl status collectd.service
             └─malarky.conf
     Active: active (running) since Tue 2022-03-15 22:14:23 GMT; 4min 0s ago
    Process: 627 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
    Process: 632 ExecStartPre=/bin/bash /usr/share/graphs1090/readback.sh (code=exited, status=0/SUCCES>
    Process: 739 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
   Main PID: 740 (collectd)
     Memory: 54.1M
        CPU: 507ms
             └─740 /usr/sbin/collectd
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "irq" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "load" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "memory" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "processes" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "rrdtool" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "swap" successfully loaded.
Mar 15 22:14:23 server collectd[740]: plugin_load: plugin "users" successfully loaded.
Mar 15 22:14:23 server collectd[740]: Systemd detected, trying to signal readiness.
Mar 15 22:14:23 server collectd[740]: Initialization complete, entering read-loop.
Mar 15 22:14:23 server systemd[1]: Started Statistics collection and monitoring daemon.
[1]+  Stopped                 systemctl status collectd.service
root@server:/etc/default# journalctl -xe
Mar 15 22:16:54 server readsb[4107]: 30104: Beast TCP input port
Mar 15 22:16:59 server airspy_adsb[449]: Push client connected to 127.0.0.1:30004 (beast)
Mar 15 22:17:01 server CRON[4115]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=>
Mar 15 22:17:01 server CRON[4116]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 15 22:17:01 server CRON[4115]: pam_unix(cron:session): session closed for user root
Mar 15 22:17:28 server sudo[4146]:  piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp >
Mar 15 22:17:28 server sudo[4146]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=>
Mar 15 22:17:28 server sudo[4146]: pam_unix(sudo:session): session closed for user root
Mar 15 22:17:28 server piaware[1171]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat>
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): fa-mlat-client 0.2.12 starting up
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Using UDP transport to 206.253.84.196 port 100>
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Listening for Beast-format results connection >
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Listening for Extended Basestation-format resu>
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Route MTU changed to 1500
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Input connected to localhost:30005
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Input format changed to BEAST, 12MHz clock
Mar 15 22:17:28 server sudo[4149]:  piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp >
Mar 15 22:17:28 server sudo[4149]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=>
Mar 15 22:17:28 server sudo[4149]: pam_unix(sudo:session): session closed for user root
Mar 15 22:17:28 server piaware[1171]: ADS-B data program 'readsb' is listening on port 30005, so far so>
Mar 15 22:17:28 server piaware[1171]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipa>
Mar 15 22:17:28 server piaware[1171]: Started faup1090 (pid 4151) to connect to readsb
Mar 15 22:17:29 server piaware[1171]: mlat-client(4148): Beast-format results connection with ::1:30104>
lines 2873-2895/2895 (END)
Mar 15 22:17:01 server CRON[4115]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Mar 15 22:17:28 server sudo[4146]:  piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Mar 15 22:17:28 server sudo[4146]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
Mar 15 22:17:28 server piaware[1171]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect>
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Using UDP transport to 206.253.84.196 port 10085
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Listening for Beast-format results connection on port 30105
Mar 15 22:17:28 server piaware[1171]: mlat-client(4148): Listening for Extended Basestation-format results connection on port >
Mar 15 22:17:28 server sudo[4149]:  piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Mar 15 22:17:28 server sudo[4149]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
Mar 15 22:17:28 server piaware[1171]: ADS-B data program 'readsb' is listening on port 30005, so far so good
Mar 15 22:17:28 server piaware[1171]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo->
Mar 15 22:17:29 server piaware[1171]: mlat-client(4148): Beast-format results connection with ::1:30104: connection established
These two files are normal.
readsb.airspyconf is the backup the installation created and not in use
I would not delete it
Lat/Lon need to be entered either via command line as suggested in the wiedehopf installer readme or manually if you know where.
