Graphs1090 for multiple dump1090 instances on the same Rpi
Hello: I spent a few days searching for a solution via google search and in this forum but didn’t find an answer. So thought I’d ask here.
I followed the steps in a different thread to setup 2 instances of Dump1090, Dump978 and piaware. I am doing that to combine data from two different antennas covering different areas. Everything works great except I have not found a way to setup graphs1090 for the second set. Is that possible?
Thanks!
The best perso who can guide you for this is @wiedehopf
no, that’s not supported with graphs1090.
well there is one solution, containers: https://sdr-enthusiasts.gitbook.io/ads-b/intro/overview
Easy to run as many instances of ultrafeeder as you want which each brings graphs1090.
Edit:
https://adsb.im/ supports multiple instances called stage2, the machine aggregating can run 1 set of local SDRs for 1090+978 but not more. So the 2nd receiver would need to be on another pi.
