Hello all… I currently use a RPI 3b along with a package installation of PiAware 3.6.3 installed from the jprochazka package installer…I’m using the performance graphs in that package, and also feeding FR24, ADSBExchange, Opensky, and Planefinder… I use the FA antenna, mounted in my attic with 25’ of LMR400, which goes to a FA external filter… That in turn connects to an SMA Y-splitter and feeds into (1) Pro Stick and (1) Pro Stick Plus. I’ve already set up a 2nd instance of dump1090-fa, and that works well…
The reason I have two receivers is because I am only ~ 3.5 mi from KISP, and directly in the flight path for Runway 24 there… I like to just track those close flights for my own viewing… So the ProPlus receiver is set with a gain of 48, and is also the instance that reports to FA and has MLAT enabled, etc… The Pro receiver has gain set to 20, and is feeding into a desktop instance of VRS and I also have Skyview set up for the 2nd instance of dump1090-fa. This setup works very well for me, as I can combine the outputs from the two into a combined feed of VRS.
What I’d like to do is set up a 2nd independent set of performance graphs for the 2nd instance of dump1090-fa… Can anyone tell me how I could go about doing this?
Thank you
Rick
