I have rpi4/trixie, no ADS-B on this unit, graphs1090 1.0.1, works as expected, all graphs display full history 2.5 years or so, etc, no issues, just use it for rpi4 hardware stats, BUT, just noticed a collectd error, not sure what I’ve done ? or how to clear/correct it ? on another rpi, with ADS-B, no such error
ve@rpi1:~ $ sudo systemctl status collectd
● collectd.service - Statistics collection and monitoring daemon
Loaded: loaded (/usr/lib/systemd/system/collectd.service; enabled; preset: enabled)
Drop-In: /etc/systemd/system/collectd.service.d
└─malarky.conf
Active: active (running) since Sun 2026-10-25 15:56:25 AEDT; 8min ago
Invocation: 61a3acd63105417b9fb2113602681145
Docs: man:collectd(1)
man:collectd.conf(5)
https://collectd.org
Main PID: 1024 (collectd)
Tasks: 8 (limit: 8796)
CPU: 1.103s
CGroup: /system.slice/collectd.service
└─1024 /usr/sbin/collectd
Oct 25 15:59:16 rpi1 collectd[1024]: rrdtool plugin: rrd_update_r (/run/collectd/localhost/interface-wlan0/if_dropped.rrd) failed: /run/collectd/localhost/i>
Oct 25 15:59:16 rpi1 collectd[1024]: <urlopen error [Errno 2] No such file or directory: '/usr/share/graphs1090/data-symlink/data/stats.json'>
Oct 25 15:59:16 rpi1 collectd[1024]: rrdtool plugin: rrd_update_r (/run/collectd/localhost/dump1090-localhost/dump1090_dbfs-NaN.rrd) failed: /run/collectd/l>
Oct 25 15:59:56 rpi1 collectd[1024]: Not sleeping because the next interval is 90.702 seconds in the past!
Oct 25 16:00:16 rpi1 collectd[1024]: <urlopen error [Errno 2] No such file or directory: '/usr/share/graphs1090/data-symlink/data/stats.json'>
ve@rpi1:/run $ ls -al /usr/share/graphs1090/data-symlink/
total 8
drwxr-xr-x 2 root root 4096 Jul 24 21:24 .
drwxr-xr-x 8 root root 4096 Jul 24 21:24 ..
lrwxrwxrwx 1 root root 11 Jul 24 21:24 data -> /run/readsb
ve@rpi1:/run $ ls -al /run/readsb
ls: cannot access '/run/readsb': No such file or directory
