Hello,
When doing a search with FindFlight method is not returning with the “inbound_faFlightID” in any of the segments, however if you search with “FlightInfoStatus” you get the inbound ID even when you search for a segment returned by the “FindFlight”. Is this a normal behavior ?
The documents suggest it will be returned if the “inbound ID” is known, which from my testing, the ID is found when directly searching it with “FlightInfoStatus” meaning, that the ID is known and it should be returned when using “FindFlight”. I hope It makes sense what I am explaining.
Here is a screenshot of the same flight with different results.
Any help will be appreciated.
