Flightinfo returning airport codes not in Allairports
Hello,
If you do a join between the table your flightinfo procedure sources its data from and the table your allairports procedure sources its data from, you’ll see that many of the origins and destinations that are showing up in the flightinfo table (including US origin and destination airports) are not in the allairports table.
Could you please update the allairports table so that we can pull down a more comprehensive list of airports to join up with the data coming from the flightinfo procedure?
The list of airports returned from the “AllAirports” function was updated last week to better correspond with our internally airport database. Hopefully this should reduce or eliminate this type of problem.
If you continue to see specific airports or airfields that appear to be missing in the other functions, let me know the specifics and I can investigate.
