Graphs & Charts From Following Site:
https://opensky-network.org/receiver-profile?s=10
(Shown here are only 4. There are many more)
This is why I thought about feeding RB again. Great feature!!!
There is one disadvantage: the max range curve is so dark that the terrain map (roads, houses etc) are hardly distinguishable, even when zoomed. The range curve cannot be turned off.
In this respect opensky-network map is much better. You can turn off range curve, making map very clear.
That was the first thing that I tried to disable when I accessed the map for the first time today, but could not find the setting.
I fed the OpenSky Network for a period of time. I don’t remember the map. Is this something new?
Another one that I liked was ADS-B Exchange.
The main reason I stopped all those, as stated previously, is that I found re-installing them after re-imaging the SD card too much work.
sudo touch /home/pi/adsbexchange.sh
sudo chmod +x /home/pi/adsbexchange.sh
sudo nano /home/pi/adsbexchange.sh
Copy-paste code below in adsbexchange.sh
Save file (Ctrl+o) and close (Ctrl+x).
NOTE: Scroll down the to near the end of code, and replace XXXXX by their actual values in following lines:
--lat XX.XXXX \
--lon XX.XXXX \
--alt XXX \
--user XXXXX \
#! /bin/sh
echo " "
echo " "
echo "\e[32mCreating adsbexchange folder...\e[39m\n"
sudo mkdir -p /home/pi/adsbexchange
echo " "
echo "\e[32mUpdating ...\e[39m\n"
sudo apt update
echo "\e[32mInstalling necessary packages (dependencies and build tools)...\e[39m\n"
sudo apt install -y git curl build-essential debhelper python-dev python3-dev socat
echo " "
echo "\e[32mDownloading source code...\e[39m\n"
cd /home/pi/adsbexchange/
sudo git clone https://github.com/mutability/mlat-client.git
echo " "
echo "\e[32mBuilding mlat-client's installation package ....\e[39m\n"
cd /home/pi/adsbexchange/mlat-client/
sudo dpkg-buildpackage -b -uc
echo " "
echo "\e[32mInstalling mlat-client ...\e[39m\n"
sudo dpkg -i mlat-client_*.deb
echo " "
echo "\e[32mCreating socat.sh file....\e[39m\n"
SOCAT_FILE=/home/pi/adsbexchange/socat.sh
sudo touch $SOCAT_FILE
sudo chmod 766 $SOCAT_FILE
sudo cat <<\EOT > $SOCAT_FILE
#! /bin/sh
while true
do
sleep 30
/usr/bin/socat -u \
TCP:localhost:30005 \
TCP:feed.adsbexchange.com:30005
done
EOT
sudo chmod 755 $SOCAT_FILE
echo " "
echo "\e[32mCreating mlat.sh file....\e[39m\n"
MLAT_FILE=/home/pi/adsbexchange/mlat.sh
sudo touch $MLAT_FILE
sudo chmod 766 $MLAT_FILE
sudo cat <<\EOT > $MLAT_FILE
#! /bin/sh
while true
do
sleep 30
/usr/bin/mlat-client \
--input-type dump1090 \
--input-connect 127.0.0.1:30005 \
--lat XX.XXXX \
--lon XX.XXXX \
--alt XXX \
--user XXXXX \
--server feed.adsbexchange.com:31090 \
--no-udp \
--results beast,connect,127.0.0.1:30104
done
EOT
sudo chmod 755 $MLAT_FILE
echo " "
echo "\e[32mAdding Startup entries in file /etc/rc.local.....\e[39m\n"
sudo sed -i '/^exit 0/i /home/pi/adsbexchange/socat.sh &\n' /etc/rc.local
sudo sed -i '/^exit 0/i /home/pi/adsbexchange/mlat.sh &\n' /etc/rc.local
echo " "
echo "\e[32m===============\e[39m"
echo "\e[32mALL DONE !\e[39m"
echo "\e[32m===============\e[39m\n"
echo "\e[31m(3) REBOOT RPi\e[39m\n"
Give following 2 commands:
cd /home/pi/
./adsbexchange.sh
After script completes its run, REBOOT PI
sudo reboot
Script for Automatic Installation of adsbexchange feeder
Thanks @abcd567.
