There will occasionally be erroneous glitches in the flight log which cause the flight track map to be screwed up. For example: today I flew from San Diego to San Jose IFR. The flight tracking map show the route nicely except for two lines going to Arkansas!
I call this the curse of the 3 digit tail number. There was probably a VFR flight over in Arkansas and the controller only put the last three digits of the tail number in.
I have seen erroneous flights which can be attributed to the 3-digit tail number curse (one shows up in my log of flights, where my aircraft becomes a Mitsubishi MU-2 twin!).
However, the particular case I’m referring to here is exactly two spurious radar hits mixed in with the rest of the track data of the last flight - the aircraft type doesn’t change.
A simple filter based on speed would easily eliminate these invalid track points.
I suspect those two points were actual hits for a VFR flight in Arkansas. The controller either corrected the tail number after a few minutes or flight following was cancelled.
