Feeding Base Station on Win 10 computer
I have PiAware running and I want to be able to feed to my computer programs like Base Station. I figure that ModeSMixer2 installed on the PiAware would work but it doesnt. Please help.
Glenn
I use modesmixer in RPi with command --outServer sbs10001:10001
and in Basestation v1.2.4.184 [Settings]-[Hardware Settings]-[Network]-Address IP of Rpi and port 10001. it works ok
also in [Settings]-[Data source] select [Network]
Alternatively you can run modesmixer for windows with
--inConnect IP-of_RPi:30005 \
and in Basestation IP use 127.0.0.1 and again port 10001
now I use Windoze 7 as 10 is complicated security and stuff so if other settings are correct and it still does not work, 10 is ‘the odd man out’
That is the way I have been feeding Base Station. I thought there was a direct way to do so I appreciate the help
Feeding data from Piaware into Basestation
It works! abcd567, you are a mad scientist! thanks for the help!
