Connect Flightfeeder to basestation
It is possible to view the data of FlightFeeder on BaseStation? How?
http://i.imgur.com/EInUAqc.png
Sorry bad english.
For example
in PPI:
./modesmixer2 --inConnect 127.0.0.1:30005 --inConnect 127.0.0.1:30106 --outServer sbs10001:10010
in BS:
IP:
port:10010
Vaclav.
If modesmixer2 will not connect to port 30106, it is likely that the output format on that port is “ext-basestation” which modesmixer does not understand.
You can check by running “sudo piaware-config -show”. If the output includes:
/mlatResultsFormat {beast,connect,localhost:30104 ext_basestation,listen,30106) ,then that is the problem.
To fix this you either need to change the output on port 30106 to something modesmixer2 understands e.g, “basestation”, or do what I chose to do to avoid upsetting the Piaware setup and add another listening port.
sudo piaware-config -mlatResultsFormat "beast,connect,localhost:30104 ext_basestation,listen,30106 beast,listen,31003"
sudo service piaware restart
Change the “30106” to “31003” in the instructions provided by fduok and that should work,
radarspotting.com/forum/index.ph … l#msg26492
With this configuration is working, thank you!
It works without having to change it, But thanks!
Where exactly do I Have to do this?
