FA Display
:question:
Hi all,
I recently started feeding FA and was wondering if there is a way to tell the difference between aircraft being tracked by ADS-B contributors vs the regular FAA feed by just looking at the map. Is there a color difference or anything like that?
Also, how does FA decided which aircraft have a visible flight tag showing and which aircraft are in shape only until moused-over?
Click “En Route” on the status to see the positions, which will show the source.
You’re looking at an airport map? It tries to declutter based on how tightly packed the airplanes are.
I probably didn’t explain it correctly. My question is, can you tell by looking at the map which tracks are ADS-B based (from everyone) versus tracks from the FAA. I guess what I am looking for is a way to tell that any particular aircraft on the map is showing in its real-time ADS-B position rather than the time delayed position just by looking at the map.
Where ?
On a flight page, click “en route” for an airborne flight. For a landed flight, click “track log & graph”
The maps don’t currently indicate the most recent type of position.
Thanks,
As a future feature FA might thing about using a different color, font or something else to indicate which positions are “live” versus FAA feeds that are delayed.
Also, is FA using any of the Mode-S non-position aircraft data that is shared with them via the various sharing methods, and how is it used?
Chris
