Im having the same issue. when i run the command that @wiedehopf posted i get "no such file or directory. when i do a ls of the directory “/etc/lighttpd/conf-available” i do not see the “dump1090-fa” file.
i would rather not have to reflash the sdcard if not needed but will if i have to.
The file 89-dump1090-fa.conf has been replaced by the file 89-skyaware.conf
cat /etc/lighttpd/conf-available/89-skyaware.conf
# Allows access to the static files that provide the dump1090 map view,
# and also to the dynamically-generated json parts that contain aircraft
# data and are periodically written by the dump1090 daemon.
# Enable alias module
## This module is normally already enabled in lighttpd, so you should not
## need to uncommment this line.
## There are some cases (e.g. when installing this on a Raspberry Pi
## that runs PiHole) in which the module has been removed from the
## default configuration, and the dump1090-fa web interface no longer
## loads properly.
## If this is what you are experiencing, or if you see messages in your
## error log like:
## (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
## then uncommenting this line and then restarting lighttpd could fix
## the issue.
## This is not enabled by default as standard lighttpd will not start if
## modules are loaded multiple times.
# server.modules += ( "mod_alias" )
alias.url += (
"/skyaware/data/" => "/run/dump1090-fa/",
"/skyaware/data-978/" => "/run/skyaware978/",
"/skyaware/" => "/usr/share/skyaware/html/"
# redirect the slash-less URL
url.redirect += (
"^/skyaware$" => "/skyaware/"
# Listen on port 8080 and serve the map there, too.
$SERVER["socket"] == ":8080" {
alias.url += (
"/data/" => "/run/dump1090-fa/",
"/data-978/" => "/run/skyaware978/",
"/" => "/usr/share/skyaware/html/"
# Add CORS header
#server.modules += ( "mod_setenv" )
$HTTP["url"] =~ "^/skyaware/data/.*\.json$" {
setenv.set-response-header = ( "Access-Control-Allow-Origin" => "*" )
# Uncomment this section to enable SSL traffic (HTTPS) - especially useful
# for .dev domains
## Listen on 8443 for SSL connections
#server.modules += ( "mod_openssl" )
#$HTTP["host"] == "piaware.example.com" {
# $SERVER["socket"] == ":8443" {
# ssl.engine = "enable"
# ssl.pemfile = "/etc/ssl/certs/combined.pem"
# ssl.ca-file = "/etc/ssl/certs/fullchain.cer"
# ssl.honor-cipher-order = "enable"
# ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"
# ssl.use-sslv2 = "disable"
# ssl.use-sslv3 = "disable"
# alias.url += (
# "/data/" => "/run/dump1090-fa/",
# "/" => "/usr/share/skyware/html/"
## Redirect HTTP to HTTPS
#$HTTP["scheme"] == "http" {
# $HTTP["host"] =~ ".*" {
# url.redirect = (".*" => "https://%0$0")
@abcd567 thanks, this happened after a power outage; think i will just redo the SD card and run again.
Easy and clean solution, better than wasting time & effort in debugging.
