after updating my pi to piaware_1.17 i get the following error message:
piaware-status
application-specific initialization failed: Can't find a usable tclx.tcl in the following directories:
/usr/share/tcltk/tcl8.5/tclx8.4 /usr/lib/tclx8.4 /usr/local/lib/tcltk/tclx8.4 /usr/local/share/tcltk/tclx8.4 /usr/lib/tcltk/tclx8.4 /usr/share/tcltk/tclx8.4 /usr/share/tcltk/tcllib1.14/tclx8.4 /lib/tclx8.4 /usr/library
/usr/lib/tclx8.4/tclx.tcl: can't read "recurse": no such variable
while executing
"lempty $recurse"
invoked from within
"if ![lempty $recurse] {
return [for_recursive_glob $var $recurse $globlist $cmd \
[expr $depth + 1]]
(file "/usr/lib/tclx8.4/globrecur.tcl" line 85)
invoked from within
"source /usr/lib/tclx8.4/globrecur.tcl"
("uplevel" body line 1)
invoked from within
"uplevel \#0 [list source [file join $dir $file]]"
("foreach" body line 3)
invoked from within
"foreach file [array names libfiles] {
if {$libfiles($file)} {
(in namespace eval "::tclx" script line 36)
invoked from within
"namespace eval ::tclx {
global auto_path auto_index tclx_library
if {[info exists tclx_library] && [string length $tclx_library]} {
set auto_..."
(file "/usr/lib/tclx8.4/tclx.tcl" line 7)
invoked from within
"source /usr/lib/tclx8.4/tclx.tcl"
invoked from within
"uplevel #0 [list source $file]"
This probably means that tclx wasn't installed properly.
/usr/share/tcltk/tcl8.5/tclx8.4 /usr/lib/tclx8.4 /usr/local/lib/tcltk/tclx8.4 /usr/local/share/tcltk/tclx8.4 /usr/lib/tcltk/tclx8.4 /usr/share/tcltk/tclx8.4 /usr/share/tcltk/tcllib1.14/tclx8.4 /usr/lib/tclx8.4/tclx8.4 /lib/tclx8.4 /usr/library
while executing
"lempty $recurse"
invoked from within
[expr $depth + 1]]
invoked from within
invoked from within
invoked from within
invoked from within
set auto_..."
invoked from within
invoked from within
while executing
"error $msg"
(procedure "tcl_findLibrary" line 108)
invoked from within
"tcl_findLibrary tclx 8.4 8.4.0 tclx.tcl TCLX_LIBRARY tclx_library"
(procedure "::tclx::Init" line 3)
invoked from within
"::tclx::Init"
(in TclX_Init)
invoked from within
"load /usr/lib/libtclx8.4.so.0 Tclx"
("package ifneeded Tclx 8.4" script)
invoked from within
"package require Tclx"
(file "/usr/lib/Tcllauncher1.5/tcllauncher.tcl" line 5)
11/17/2014 18:15:37 ****************************************************
11/17/2014 18:15:37 piaware version 1.17 is running, process ID 17834
11/17/2014 18:15:37 your system info is: Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux
11/17/2014 18:15:38 connecting to FlightAware eyes.flightaware.com/1200
11/17/2014 18:15:44 FlightAware server SSL certificate validated
11/17/2014 18:15:44 encrypted session established with FlightAware
invalid command name "parse_mac_address_from_line"
while executing
"parse_mac_address_from_line $line"
(object "::adept" method "::fa_adept::AdeptClient::get_mac_address" body line 20)
invoked from within
"get_mac_address"
(object "::adept" method "::fa_adept::AdeptClient::get_mac_address_or_quit" body line 2)
invoked from within
"get_mac_address_or_quit"
(object "::adept" method "::fa_adept::AdeptClient::login" body line 24)
invoked from within
"login"
(object "::adept" method "::fa_adept::AdeptClient::connect" body line 59)
invoked from within
"adept connect"
(procedure "main" line 80)
invoked from within
"main $argv"
invoked from within
"if {!$tcl_interactive} {
main $argv
(file "/usr/lib/piaware/main.tcl" line 123)
invoked from within
"source /usr/lib/piaware/main.tcl"
invoked from within
"uplevel #0 source $path"
from tcllauncher running "piaware -p /var/run/piaware.pid"
I’m running a Raspberry Pi Typ A with a WLAN-Stick.
11/18/2014 16:27:30 ****************************************************
11/18/2014 16:27:30 piaware version 1.17 is running, process ID 26037
11/18/2014 16:27:30 your system info is: Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux
11/18/2014 16:27:30 connecting to FlightAware eyes.flightaware.com/1200
11/18/2014 16:27:36 FlightAware server SSL certificate validated
11/18/2014 16:27:36 encrypted session established with FlightAware
11/18/2014 16:27:36 no eth0 device, using 74:da:38:00:5f:0c from device 'wlan0'
11/18/2014 16:27:37 no eth0 device, using 74:da:38:00:5f:0c from device 'wlan0'
too many nested evaluations (infinite loop?)
(procedure "::tcl::clock::format" line 4)
invoked from within
"clock format [clock seconds] -format "%D %T" -gmt 1"
(procedure "log_locally" line 3)
invoked from within
"log_locally $text"
(procedure "::logger" line 3)
invoked from within
"::logger $text"
(object "::adept" method "::fa_adept::AdeptClient::logger" body line 3)
invoked from within
"logger "no eth0 device, using $mac from device '$device'""
(object "::adept" method "::fa_adept::AdeptClient::get_mac_address" body line 25)
invoked from within
"get_mac_address"
invoked from within
(object "::adept" method "::fa_adept::AdeptClient::send_log_message" body line 8)
invoked from within
"adept send_log_message $text"
(procedure "::logger" line 4)
invoked from within
"::logger $text"
invoked from within
invoked from within
"get_mac_address"
invoked from within
invoked from within
invoked from within
"::logger $text"
invoked from within
invoked from within
"get_mac_address"
invoked from within
invoked from within
Figured it out. For the brave, edit /usr/lib/fa_adept_packages/fa_adept_client.tcl and change logger to log_locally at line 867. Otherwise we’ll release a new version soon. I had correctly fixed the problem for the Model A and A+ except a last minute change I made (changing from puts to logger) that didn’t get tested. Boo!
1.17-3 will have a minor performance improvement in this area as well.
