Did anyone try to build it on the latest void ARM platform?
Here is where I got so far:
xbps-install -y tcl openssl-c_rehash autoconf
TCLlauncher seems to be needed for piaware
git clone https://github.com/flightaware/tcllauncher
$ cd tcllauncher
$ autoconf
$ ./configure --prefix=/opt/tcl
$ make
$ make install
This will not build
autoconf
configure.in:38: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:38: You should run autoupdate.
./lib/autoconf/general.m4:204: AC_HELP_STRING is expanded from...
tclconfig/tcl.m4:43: TEA_PATH_TCLCONFIG is expanded from...
configure.in:38: the top level
configure.in:39: warning: The macro `AC_TRY_COMPILE' is obsolete.
configure.in:39: You should run autoupdate.
./lib/autoconf/general.m4:2847: AC_TRY_COMPILE is expanded from...
tclconfig/tcl.m4:353: TEA_LOAD_TCLCONFIG is expanded from...
configure.in:39: the top level
configure.in:62: warning: The macro `AC_TRY_COMPILE' is obsolete.
configure.in:62: You should run autoupdate.
lib/m4sugar/m4sh.m4:692: _AS_IF_ELSE is expanded from...
lib/m4sugar/m4sh.m4:699: AS_IF is expanded from...
./lib/autoconf/general.m4:2249: AC_CACHE_VAL is expanded from...
./lib/autoconf/general.m4:2270: AC_CACHE_CHECK is expanded from...
tclconfig/tcl.m4:3255: TEA_SETUP_COMPILER is expanded from...
configure.in:62: the top level
configure.in:62: warning: The macro `AC_TRY_LINK' is obsolete.
./lib/autoconf/general.m4:2920: AC_TRY_LINK is expanded from...
tclconfig/tcl.m4:2283: TEA_MISSING_POSIX_HEADERS is expanded from...
configure.in:62: warning: The macro `AC_HAVE_HEADERS' is obsolete.
./lib/autoconf/oldnames.m4:35: AC_HAVE_HEADERS is expanded from...
configure.in:133: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:133: You should run autoupdate.
tclconfig/tcl.m4:729: TEA_ENABLE_THREADS is expanded from...
configure.in:133: the top level
configure.in:140: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:140: You should run autoupdate.
tclconfig/tcl.m4:672: TEA_ENABLE_SHARED is expanded from...
configure.in:140: the top level
configure.in:148: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:148: You should run autoupdate.
tclconfig/tcl.m4:1038: TEA_CONFIG_CFLAGS is expanded from...
configure.in:148: the top level
configure.in:148: warning: The macro `AC_TRY_LINK' is obsolete.
configure.in:148: warning: The macro `AC_TRY_COMPILE' is obsolete.
configure.in:148: warning: The macro `AC_TRY_RUN' is obsolete.
./lib/autoconf/general.m4:2997: AC_TRY_RUN is expanded from...
tclconfig/tcl.m4:2699: TEA_TCL_EARLY_FLAG is expanded from...
tclconfig/tcl.m4:2712: TEA_TCL_EARLY_FLAGS is expanded from...
tclconfig/tcl.m4:2746: TEA_TCL_64BIT_FLAGS is expanded from...
configure.in:154: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:154: You should run autoupdate.
tclconfig/tcl.m4:857: TEA_ENABLE_SYMBOLS is expanded from...
configure.in:154: the top level
configure.in:205: warning: The macro `AC_HELP_STRING' is obsolete.
configure.in:205: You should run autoupdate.
configure.in:205: the top level
configure.in:225: warning: AC_C_BIGENDIAN should be used with AC_CONFIG_HEADERS
Therefore this will not build:
git clone GitHub - flightaware/piaware: Client-side package and programs for forwarding ADS-B data to FlightAware
make -C package install
make[1]: Entering directory ‘/home/radar/piaware/package’
install -d /usr/lib/piaware_packages /usr/lib/piaware_packages/ca
install fa_piaware_config.tcl fa_adept_client.tcl fa_sudo.tcl fa_services.tcl fa_sysinfo.tcl fa_gps.tcl piaware.tcl tryfinallyshim.tcl egm96.tcl egm96geoid.tcl pkgIndex.tcl /usr/lib/piaware_packages
install ca/*.pem /usr/lib/piaware_packages/ca
c_rehash /usr/lib/piaware_packages/ca
Doing /usr/lib/piaware_packages/ca
make -C helpers install
make[2]: Entering directory ‘/home/radar/piaware/package/helpers’
install -d /usr/lib/piaware_packages/helpers
install -m 0755 update-piaware-config droproot restart-receiver restart-network /usr/lib/piaware_packages/helpers
make[2]: Leaving directory ‘/home/radar/piaware/package/helpers’
make -C fa_adept_codec install
make[2]: Entering directory ‘/home/radar/piaware/package/fa_adept_codec’
install -d /usr/lib/fa_adept_codec
install fa_adept_codec.tcl fa_adept_schema.tcl none.codec adept_1.x.codec adept_2.1.codec adept_2.2.codec pkgIndex.tcl /usr/lib/fa_adept_codec
make[2]: Leaving directory ‘/home/radar/piaware/package/fa_adept_codec’
make[1]: Leaving directory ‘/home/radar/piaware/package’
make -C programs/piaware install
make[1]: Entering directory ‘/home/radar/piaware/programs/piaware’
which: no tcllauncher in (/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/sbin:/usr/local/bin)
install -d /usr/bin /usr/lib/piaware
install -m 0755 /usr/bin/piaware
install: missing destination file operand after ‘/usr/bin/piaware’
Try ‘install --help’ for more information.
make[1]: *** [Makefile:15: install] Error 1
make[1]: Leaving directory ‘/home/radar/piaware/programs/piaware’
make: *** [Makefile:19: install] Error 2
It would be very nice having a void linux package containing all the necessary components ![]()
