Having a problem similar to that discussed here, but more constant.
My map displays:
Problem fetching data from dump1090.
AJAX call failed (error: Not Found). Maybe dump1090 is no longer running?
The displayed map data will be out of date.
every few minutes, it sits there for a bit, then erases and re-populates the screen. Lather, rinse, repeat.
From the logs and messages, it looks like the dongle is falling offline every few minutes.
Voltages look good:
sudo dmesg --ctime | grep voltage
pi@piaware:~ $
Hardware:
pi ZeroW, generic RTL 2838 dongle.
/var/log/piaware.log is showing:
Oct 9 21:08:55 piaware piaware[393]: no ADS-B data program seen listening on port 30005 for 61 seconds, next check in 60s
Oct 9 21:08:55 piaware piaware[393]: mlat-client(717): Connection to localhost:30005 lost: [Errno 111] Connection refused
Oct 9 21:08:55 piaware piaware[393]: mlat-client(717): Reconnecting in 0.5 seconds
Oct 9 21:08:56 piaware piaware[393]: mlat-client(717): Connection to localhost:30005 lost: [Errno 111] Connection refused
Oct 9 21:08:56 piaware piaware[393]: mlat-client(717): Reconnecting in 30.0 seconds
Oct 9 21:09:25 piaware piaware[393]: mlat-client(717): Beast-format results connection with 127.0.0.1:30104: [Errno 111] Connection refused
Oct 9 21:09:26 piaware piaware[393]: mlat-client(717): Connection to localhost:30005 lost: [Errno 111] Connection refused
Oct 9 21:09:26 piaware piaware[393]: mlat-client(717): Reconnecting in 0.5 seconds
Oct 9 21:09:27 piaware piaware[393]: mlat-client(717): Connection to localhost:30005 lost: [Errno 111] Connection refused
Oct 9 21:09:27 piaware piaware[393]: mlat-client(717): Reconnecting in 30.0 seconds
Oct 9 21:09:56 piaware piaware[393]: ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
Oct 9 21:09:56 piaware piaware[393]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 42.810 --lon -73.617
Oct 9 21:09:56 piaware piaware[393]: Started faup1090 (pid 1208) to connect to dump1090-fa
Oct 9 21:09:56 piaware piaware[393]: mlat-client(717): Beast-format results connection with ::1:30104: connection established
Oct 9 21:09:58 piaware piaware[393]: mlat-client(717): Input connected to localhost:30005
Oct 9 21:09:58 piaware piaware[393]: mlat-client(717): Input format changed to BEAST, 12MHz clock
I am seeing these in /var/log/messages:
Oct 8 00:05:32 piaware kernel: [359523.437716] usb 1-1.4: USB disconnect, device number 48
Oct 8 00:05:32 piaware kernel: [359523.842391] usb 1-1.4: new high-speed USB device number 49 using dwc_otg
Oct 8 00:05:32 piaware kernel: [359524.084426] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
Oct 8 00:05:32 piaware kernel: [359524.084483] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 8 00:05:32 piaware kernel: [359524.084510] usb 1-1.4: Product: RTL2838UHIDIR
Oct 8 00:05:32 piaware kernel: [359524.084529] usb 1-1.4: Manufacturer: Realtek
Oct 8 00:05:32 piaware kernel: [359524.084545] usb 1-1.4: SerialNumber: 00000001
Oct 8 00:05:32 piaware mtp-probe: checking bus 1, device 49: “/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4”
Oct 8 00:05:32 piaware mtp-probe: bus: 1, device: 49 was not an MTP device
Oct 8 00:10:17 piaware rsyslogd: [origin software=“rsyslogd” swVersion=“8.2102.0” x-pid=“219” x-info=“https://www.rsyslog.com”] rsyslogd was HUPed
Oct 8 00:18:33 piaware kernel: [360305.051168]
Oct 8 00:18:33 piaware kernel: [360305.051203] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 4
Oct 8 00:18:33 piaware kernel: [360305.052279]
Oct 8 00:18:33 piaware kernel: [360305.052295] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 0
Oct 8 00:18:33 piaware kernel: [360305.264677] usb 1-1.4: USB disconnect, device number 49
Oct 8 00:18:34 piaware kernel: [360305.667595] usb 1-1.4: new high-speed USB device number 50 using dwc_otg
Oct 8 00:18:34 piaware kernel: [360305.910054] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
Oct 8 00:18:34 piaware kernel: [360305.910120] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 8 00:18:34 piaware kernel: [360305.910146] usb 1-1.4: Product: RTL2838UHIDIR
Oct 8 00:18:34 piaware kernel: [360305.910164] usb 1-1.4: Manufacturer: Realtek
Oct 8 00:18:34 piaware kernel: [360305.910181] usb 1-1.4: SerialNumber: 00000001
Oct 8 00:18:34 piaware mtp-probe: checking bus 1, device 50: “/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4”
Oct 8 00:18:34 piaware mtp-probe: bus: 1, device: 50 was not an MTP device
Oct 8 00:31:12 piaware kernel: [361063.539600] usb 1-1.4: USB disconnect, device number 50
Oct 8 00:31:12 piaware kernel: [361063.942771] usb 1-1.4: new high-speed USB device number 51 using dwc_otg
Oct 8 00:31:12 piaware kernel: [361064.185047] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
Oct 8 00:31:12 piaware kernel: [361064.185118] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
I could use some help finding a clue as to what is going on.
Thanks!
