I’ve just done a completely clean reimage and continue to have this intermittent issue where the GUI says:
"Problem fetching data from dump1090.
AJAX call failed (error: Not Found). Maybe dump1090 is no longer running?
The displayed map data will be out of date.”
I had the same issue previously, but thought an update might have gotten screwed up. So, I’ve now done a new image install and am having the same issue.
I’m looking through logs and see:
Jul 27 13:04:11 piaware dump1090-fa[15186]: Mon Jul 27 13:04:11 2020 UTC dump1090-fa 3.8.1 starting up.
Jul 27 13:04:11 piaware dump1090-fa[15186]: rtlsdr: no supported devices found.
Jul 27 13:04:11 piaware systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
Jul 27 13:04:11 piaware systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
But, everything appears to be working correctly right now…but then later it seems to crash in to the GUI. Have not yet been able to login to console to check status when it crashed in the GUI.
I have a regular Raspberry Pi 3b+ and the FlightAware Pro Stick Plus ADS-B USB Receiver with Built-in Filter.
That is a good result. That command is searching for errors which were logged indicating a low voltage condition. No results = no low voltage problem (since last reboot or so, anyway)
I am sure that someone could write a script to wrap around it, but what it is doing is asking for a list of any entries in the log that contain the word “voltage” (that’s what ‘grep’ does).
If it finds that word, it returns a list of every time it appears, and if it doesn’t find it, it returns an empty list - i.e. nothing.
So it makes sense if you have a little background in what the command is supposed to do, but maybe not so much if you are just coming across it in a forum.
I’m having the same issue, and the crash is causing a gap in coverage which is quite noticeable. I haven’t done a re-image yet, but I was just about ready to until I saw this post.
