dump1090-mutability commit 4711eaf '--net-fatsv-port' error
Hi,
I updated to the dump1090-mutability tip code today and it no longer starts on my ubuntu system, reporting ‘Unknown or not enough arguments for option ‘–net-fatsv-port’’.
sudo dpkg-reconfigure dump1090-mutability sets ‘FATSV-format output connections (0 disables) on port 10001’
I am running piaware 2.1-5.
I’m assuming this has something to do with commit 4711eaf / fix #92 - rolling back to #1a2926b resolves the issue.
Apologies if this is still a work in progress… Just thought this might help if someone is seeing the same issue.
Thanks,
Peter
–net-fatsv-port was removed because it’s no longer used (piaware has not used data on that port for some time now).
If you run into more problems, can I get you to report them as github issues.
Thanks for confirming… Will do.
