The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun May 25 15:21:32 2025 from 192.168.178.58
fa@FlightAware:~ $ sudo apt update
sudo apt full-upgrade
sudo reboot
Hit:4 https://repo-feed.flightradar24.com flightradar24 InRelease
Hit:2 https://www.flightaware.com/adsb/piaware/files/packages bullseye InRelease
Hit:1 http://www.flightaware.com/mirror/raspbian/raspbian bullseye InRelease
Hit:3 http://www.flightaware.com/mirror/raspberrypi/debian bullseye InRelease
Reading package lists… Done
Building dependency tree… Done
All packages are up to date.
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
libbladerf2 raspinfo
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Last login: Sun May 25 16:17:40 2025 from 192.168.178.58
fa@FlightAware:~ $ wget https://de.flightaware.com/adsb/piaware/files/packages/pool/piaware/f/flightaware-apt-repository/flightaware-apt-repository_1.2_all.deb
sudo dpkg -i flightaware-apt-repository_1.2_all.deb
–2025-05-25 16:20:10-- https://de.flightaware.com/adsb/piaware/files/packages/pool/piaware/f/flightaware-apt-repository/flightaware-apt-repository_1.2_all.deb
Resolving de.flightaware.com (de.flightaware.com)… 2606:4700:4400::6812:27c9,2606:4700:4400::ac40:9437, 172.64.148.55, …
Connecting to de.flightaware.com (de.flightaware.com)|2606:4700:4400::6812:27c9:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 4996 (4.9K) [application/x-debian-package]
Saving to: ‘flightaware-apt-repository_1.2_all.deb.10’
flightaware-apt-rep 100%[===================>] 4.88K --.-KB/s in 0.001s
2025-05-25 16:20:11 (5.23 MB/s) - ‘flightaware-apt-repository_1.2_all.deb.10’ saved [4996/4996]
(Reading database … 56626 files and directories currently installed.)
Preparing to unpack flightaware-apt-repository_1.2_all.deb …
Unpacking flightaware-apt-repository (1.2) over (1.2) …
Setting up flightaware-apt-repository (1.2) …
fa@FlightAware:~ $
sudo apt install piaware
piaware is already the newest version (10.0.1~bpo11+1).
allow-auto-updates is unchanged
sudo apt install dump1090-fa
dump1090-fa is already the newest version (10.0.1~bpo11+1).
sudo apt install dump978-fa
dump978-fa is already the newest version (10.0.1~bpo11+1).
PiAware - Claim and Link a Brand New PiAware Ground Station
Unfortunately, FlightAware hasn’t found a new, unclaimed PiAware feeder to claim.
FlightAware searches for PiAware connections on the same global IP (77.2.228.97 or 2a02:3100:9d2d:f600:c83d:bf57:6a1a:8834) as your connection. If you are on the same LAN as the PiAware device, then we should be able to find the receiver and claim it for you.
You should wait a few minutes after plugging in your PiAware device before expecting it to be connected to FlightAware. Try checking cable connections, waiting a few moments, and trying again.
If you are unable to use the automatic claim feature, please contact ADS-B Support.
Check Again for my PiAware
Linked PiAware Receivers (justfun2405)
Great news! Your account is associated with the following PiAware receivers and you can view your statistics here:
Site 238801 - HOME - 6453fdb1-3681-4f33-9af5-322e96ebd0f4: PiAware (SD Card) 10.0 added Sonntag, 22 Dezember 2024 (2a02:3100:9d2d:f600:7129:4f2c:c28c:5179 / 192.168.178.83)
1Ihre ADSB-Statistiken
FlightAware beginnt unverzüglich mit der Bearbeitung Deiner Daten und zeigt Deine Statistiken innerhalb von 30 Minuten.Sie finden Ihre ADS-B Statistiken unter: Carsten Linke ADS-B Feeder Statistics - FlightAware
Die FlightAware-Statistikseite zeigt Ihnen auch die lokale IP-Adresse Ihres Gerätes und bietet einen Link zur direkten Verbindung. Auf der Statistikseite von FlightAware können Sie außerdem die geographische Position Ihres Standortes und die Antennenhöhe konfigurieren.
2Erfolgreich!
Vergessen Sie nicht, dass die Signale der Flugzeuge nicht geeignet sind, um Objekte zu durchdringen. Deshalb sollte sich die Antenne ohne Hindernisse in “Blickrichtung” zum Himmel befinden. Die optimalste Anbringung der Antenne wäre draußen auf dem Dach für eine Reichweite von mehr als 250 mi / 400 km.
