The stick is fine, after that problem it worked again without issues.
Logs simply say that no device was found. Have these entries after i performed the reboot
Why did it fail without changing something and why is it working again now?
Mar 22 08:34:35 Raspi4 systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
Mar 22 08:34:35 Raspi4 systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Mar 22 08:34:35 Raspi4 dump1090-fa[27837]: Sun Mar 22 08:34:35 2020 CET dump1090-fa 3.8.0 starting up.
Mar 22 08:34:35 Raspi4 dump1090-fa[27837]: rtlsdr: no supported devices found.
Mar 22 08:34:35 Raspi4 systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
Mar 22 08:34:35 Raspi4 systemd[1]: dump1090-fa.service: Failed with result 'exit-code'.
Mar 22 08:35:06 Raspi4 systemd[1]: dump1090-fa.service: Service RestartSec=30s expired, scheduling restart.
Mar 22 08:35:06 Raspi4 systemd[1]: dump1090-fa.service: Scheduled restart job, restart counter is at 69.
Exact this problem happened with me few days ago on Ubuntu on my Desktop PC. Re-plugging and rebooting did not solve the problem. Changing USB slot (from back slots to front slots of PC) solved the problem.
NOTE:
The problem was NOT due to VM. Ubuntu was booted directly from hard drive (I have dual boot system Win 8 / Ubuntu 18 and can choose one at boot).
Electrolytic capacitors tend to work less well when cold especially when they dry out with age/heat effects. Cold temperatures might just tip balance and affect stable operation of the dongle when cold.
It might even be a subtle issue as the combination of an ageing PI power supply and the dongle capacitors failing where under a very specific situation, the dongle crashes e.g. a spike in CPU usage might cause the dongle to experience a power dip that healthy capacitors in the dongle would otherwise guard against.
The device runs since three months outdoor without that issue. I am using the original power supply for the Pi4 and never had it.
Currently we are around freezing point, but the device ran flawless during that period with much lower environment temperatures.
As the device is used for FA only, the CPU is more or less in almost idle mode.
The only thing that changes is the amount of flights due to the current situation regarding Covid-19.
Maybe it cools down because there is not much to do for it.
I keep an eye on it.
Some more log entries. Seem to be a “lost & found”
Mar 23 07:57:39 Raspi4 dump1090-fa[879]: Found Rafael Micro R820T tuner
Mar 23 07:57:39 Raspi4 dump1090-fa[879]: rtlsdr: tuner gain set to 40.2 dB
Mar 23 07:57:39 Raspi4 dump1090-fa[879]: Allocating 4 zero-copy buffers
Mar 23 07:59:10 Raspi4 dump1090-fa[879]: cb transfer status: 1, canceling...
Mar 23 07:59:10 Raspi4 dump1090-fa[879]: rtlsdr: rtlsdr_read_async returned unexpectedly, probably lost the USB device, bailing out
Mar 23 07:59:10 Raspi4 dump1090-fa[879]: Mon Mar 23 07:59:10 2020 CET Waiting for receive thread termination
Mar 23 07:59:10 Raspi4 dump1090-fa[879]: Reattaching kernel driver failed!
Mar 23 07:59:10 Raspi4 dump1090-fa[879]: Mon Mar 23 07:59:10 2020 CET Abnormal exit.
Mar 23 07:59:10 Raspi4 systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
Mar 23 07:59:10 Raspi4 systemd[1]: dump1090-fa.service: Failed with result 'exit-code'.
Hm, the device is fully covered by the roof and it is in a box with an additional cover. Rain would need to go upwards to hit it, mission impossible
If this is the case, it can be air humidity only.
However i am checking the connectors later
EDIT:
Today the device lost it’s USB stick exactly at the same time of yesterday. Wonder if this is by chance or something else kicked in. Since i rebooted again, it works without issues.
Only change i did was a gain increase from 40.2 to 42.1 after the reboot.
Today third day in a row having the issues in the morning hours.
I checked hardware physically, can’t detect anything, but corrosion is always hard to determine if it’s just started.
