FlightAware Discussions
Dump1090-fa no display
Well it was working fine but I’ve obviously done something to mess it up :frowning:
Typing
dump1090-fa
was giving me the standard text screen display but now all I get is
rtlsdr: no supported devices found
My system consists of a RPi with airspy.
I installed the FA SD card image then used the Wiedehopf instructions 1a
A google search has not shown up anything pertinent so I’m asking here.
Drastic measure would be to re-install the FS SD card image again and redo but hopefully it is just a configuration that I have mistakenly changed somewhere.
Any ideas?
Martin
That’s expected, dump1090-fa is running in net-only mode if you configured it correctly as per the instructions.
Did you go 1a) or 1b)?
Your stats show you as online, or are you using a second station?
https://flightaware.com/adsb/stats/user/hs0zed
Anyway i highly recommend using my script, much less to get wrong:
https://github.com/wiedehopf/airspy-conf#installation
It should “just work”.
Hi,
Many thanks for the reply.
Yes the system is working and it is online.
It’s just the dump1090-fa display that no longer does what it did before.
I’m not sure what happened. I was doing several things, always dangerous. Essentially though I was just adjusting the various receiver options when I noticed the Piaware screen was telling me it had not received any messages from the receiver in a while. I think in the end this turned out to be a bad USB cable, though not before I had gone back through the configuration adjustments.
I’m sure I went with 1a as I have a Piaware SD card image and your instructions clearly state it should be either or, and yes it did indeed “just work” :slightly_smiling_face:
Well if those options are malformed like forgetting or adding a dash, then airspy_adsb might not start anymore.
You can check that with
sudo journalctl -u airspy_adsb
You can also check the dump1090-fa log, but as you probably were not adjust those options, it shouldn’t matter.
Okay well major egg on face at this end :laughing:
I’ve been using the wrong command :scream:
I had thought it should be dump1090-fa but since you assured me that was clearly working okay, and I agree I did a bit of digging and I should have been using view1090-fa :flushed::roll_eyes:
It does raise one question for me though, is there a list of all commands related to piaware, dump1090 and others?
Martin
Not that i’m aware of.
Most people would just look at the webinterface anyway instead of using view1090-fa.
