Ok I’m really happy that we will get a new toy in coming days - support for 978 MHz UAT ADS-B.
So, let’s discuss the hardware setup. Ok computer part should not be relevant, but:
SDR. Which one? Orange ProStick? rtl-sdr.com? NooElec Smart?
Preamp. Yes, no, which one?
Filter. FlightAware cylinder, something alternative (I saw smaller cheaper ones sold on Ebay), no filter?
Filter wo preamp, preamp wo filter.
Antenna. Length. Types. Is FlighAware antenna good enough? DIY, etc.
About SDRs. There is newer Smart XTR. NooElec say they don’t recommend this one for ADS-B as there’s “a small gap in frequency capability near 1100MHz. As such, we do NOT recommend this device for ADS-B usage.”
About everything else: I’m now experimenting with NooElec Smart + FlightAware filter + different antennas, ordered some online.
I use the FlightAware pro stick (Yellow/Orange) with the older 1090 filter and into my home made can-tenna cut for 978 mhz. By the info on the graphs I see aircraft out as far as 81 miles. I use RG6 CATV coax.
NooElec Smart + FlightAware filter + NooElec 978 MHz 5 dB antenna.
It’s located outdoors, on the balcony. I live on the hill, so sky view isn’t too bad and I see about 20 airplanes currently on my 1090 MHz.
Well, one (one!) message in the last 20 hours. That’s definitely better than 0, but something is probably wrong.
Crap? Yes, likely. I compared their 1090 5 dB one (I got both 978 and 1090) with cheap 2.5 dB one from Ebay and with paper clip cut to 153 mm. Both cheap antenna and paper clip won. Thinking about returning those. Will try coax.
I replaced NooElec 978 MHz 5 dB antenna with 153 mm paper clip. Now getting few UAT messages, about two per hour. So paper clip is better than their antenna. Will return.
Will piece of 1/4 wave wire on the whip stand be better that piece of 1/2 wave wire plugged in directly? I’ll try of course. BTW I’m now generating a higher resolution heatmap, I see some hot zones around 978 MHz here, maybe that’s cause of interference.
That one you posted seemed quite narrow and everything in the heatmap didn’t really look like noise, rather just a pattern from the receiver but i don’t know.
