Over the past week, I have experienced loss of data on the Skyview page. The Feeder shows that it is checking in, but I am getting no data. Wi-fi connection is strong. The setup has been running flawlessly for 7 weeks, and just this past week the problem has come up. Any ideas?
Log File:
[2017-09-01 19:06 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:07 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 19:07 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 19:07 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 19:07 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 19:07 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 19:11 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:16 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:21 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:22 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 19:22 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 19:22 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 19:22 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 19:22 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 19:26 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:31 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:36 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:37 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 19:37 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 19:37 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 19:37 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 19:37 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 19:40 EDT] no new messages received in 3685 seconds, it might just be that there haven’t been any aircraft nearby but I’m going to try to restart everything, just in case…
[2017-09-01 19:40 EDT] faup1090 exited with SIG SIGHUP
[2017-09-01 19:40 EDT] attempting to restart dump1090…
[2017-09-01 19:40 EDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2017-09-01 19:40 EDT] dump1090 restart appears to have been successful
[2017-09-01 19:41 EDT] ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
[2017-09-01 19:41 EDT] Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 32.907 --lon -79.801
[2017-09-01 19:41 EDT] Started faup1090 (pid 2227) to connect to dump1090-fa
[2017-09-01 19:41 EDT] 108 msgs recv’d from dump1090-fa (0 in last 5m); 108 msgs sent to FlightAware
[2017-09-01 19:42 EDT] mlat-client(813): Lost connection to localhost:30005
[2017-09-01 19:42 EDT] mlat-client(813): Reconnecting in 30.0 seconds
[2017-09-01 19:42 EDT] mlat-client(813): Beast-format results connection with 127.0.0.1:30104: connection lost
[2017-09-01 19:42 EDT] lost connection to dump1090-fa via faup1090
[2017-09-01 19:42 EDT] faup1090 exited normally
[2017-09-01 19:42 EDT] reconnecting to dump1090-fa
[2017-09-01 19:42 EDT] ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
[2017-09-01 19:42 EDT] Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 32.907 --lon -79.801
[2017-09-01 19:42 EDT] Started faup1090 (pid 2269) to connect to dump1090-fa
[2017-09-01 19:42 EDT] mlat-client(813): Input connected to localhost:30005
[2017-09-01 19:42 EDT] mlat-client(813): Input format changed to BEAST, 12MHz clock
[2017-09-01 19:42 EDT] mlat-client(813): Beast-format results connection with 127.0.0.1:30104: connection established
[2017-09-01 19:46 EDT] 314 msgs recv’d from dump1090-fa (206 in last 5m); 314 msgs sent to FlightAware
[2017-09-01 19:51 EDT] 538 msgs recv’d from dump1090-fa (224 in last 5m); 538 msgs sent to FlightAware
[2017-09-01 19:52 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 19:52 EDT] mlat-client(813): Server status: clock unstable
[2017-09-01 19:52 EDT] mlat-client(813): Receiver: 26.3 msg/s received 14.0 msg/s processed (53%)
[2017-09-01 19:52 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
[2017-09-01 19:52 EDT] mlat-client(813): Results: 2.3 positions/minute
[2017-09-01 19:52 EDT] mlat-client(813): Aircraft: 11 of 14 Mode S, 5 of 10 ADS-B used
[2017-09-01 19:56 EDT] 694 msgs recv’d from dump1090-fa (156 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:01 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:06 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:07 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 20:07 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 20:07 EDT] mlat-client(813): Receiver: 4.5 msg/s received 2.5 msg/s processed (56%)
[2017-09-01 20:07 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 20:07 EDT] mlat-client(813): Results: 1.2 positions/minute
[2017-09-01 20:07 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 20:11 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:16 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:21 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:22 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 20:22 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 20:22 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 20:22 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 20:22 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 20:26 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:31 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:36 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:37 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 20:37 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 20:37 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 20:37 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 20:37 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 20:41 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:46 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:51 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:52 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 20:52 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 20:52 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 20:52 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 20:52 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 20:55 EDT] no new messages received in 3703 seconds, it might just be that there haven’t been any aircraft nearby but I’m going to try to restart everything, just in case…
[2017-09-01 20:55 EDT] faup1090 exited with SIG SIGHUP
[2017-09-01 20:55 EDT] attempting to restart dump1090…
[2017-09-01 20:55 EDT] attempting to restart dump1090-fa using ‘systemctl --no-block try-restart dump1090-fa.service < /dev/null’…
[2017-09-01 20:55 EDT] dump1090 restart appears to have been successful
[2017-09-01 20:56 EDT] ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
[2017-09-01 20:56 EDT] Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 32.907 --lon -79.801
[2017-09-01 20:56 EDT] Started faup1090 (pid 2990) to connect to dump1090-fa
[2017-09-01 20:56 EDT] 694 msgs recv’d from dump1090-fa (0 in last 5m); 694 msgs sent to FlightAware
[2017-09-01 20:57 EDT] mlat-client(813): Lost connection to localhost:30005
[2017-09-01 20:57 EDT] mlat-client(813): Reconnecting in 30.0 seconds
[2017-09-01 20:57 EDT] mlat-client(813): Beast-format results connection with 127.0.0.1:30104: connection lost
[2017-09-01 20:57 EDT] lost connection to dump1090-fa via faup1090
[2017-09-01 20:57 EDT] faup1090 exited normally
[2017-09-01 20:57 EDT] reconnecting to dump1090-fa
[2017-09-01 20:57 EDT] ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
[2017-09-01 20:57 EDT] Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 32.907 --lon -79.801
[2017-09-01 20:57 EDT] Started faup1090 (pid 3028) to connect to dump1090-fa
[2017-09-01 20:57 EDT] mlat-client(813): Input connected to localhost:30005
[2017-09-01 20:57 EDT] mlat-client(813): Input format changed to BEAST, 12MHz clock
[2017-09-01 20:57 EDT] mlat-client(813): Beast-format results connection with 127.0.0.1:30104: connection established
[2017-09-01 21:01 EDT] 986 msgs recv’d from dump1090-fa (292 in last 5m); 986 msgs sent to FlightAware
[2017-09-01 21:06 EDT] 1298 msgs recv’d from dump1090-fa (312 in last 5m); 1298 msgs sent to FlightAware
[2017-09-01 21:07 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 21:07 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 21:07 EDT] mlat-client(813): Receiver: 43.4 msg/s received 19.7 msg/s processed (45%)
[2017-09-01 21:07 EDT] mlat-client(813): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
[2017-09-01 21:07 EDT] mlat-client(813): Results: 29.2 positions/minute
[2017-09-01 21:07 EDT] mlat-client(813): Aircraft: 11 of 17 Mode S, 6 of 7 ADS-B used
[2017-09-01 21:11 EDT] 1388 msgs recv’d from dump1090-fa (90 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:16 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:21 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:22 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 21:22 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 21:22 EDT] mlat-client(813): Receiver: 0.9 msg/s received 0.4 msg/s processed (44%)
[2017-09-01 21:22 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 21:22 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 21:26 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:31 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:36 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:37 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 21:37 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 21:37 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 21:37 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 21:37 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 21:41 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:46 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:51 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 21:52 EDT] mlat-client(813): Receiver status: connected
[2017-09-01 21:52 EDT] mlat-client(813): Server status: not synchronized with any nearby receivers
[2017-09-01 21:52 EDT] mlat-client(813): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%)
[2017-09-01 21:52 EDT] mlat-client(813): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2017-09-01 21:52 EDT] mlat-client(813): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2017-09-01 21:56 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
[2017-09-01 22:01 EDT] 1388 msgs recv’d from dump1090-fa (0 in last 5m); 1388 msgs sent to FlightAware
