I just got started with piaware and was wondering if it’s possible to process the raw IQ data from rtl_tcp using dump1090 on another machine on the network. From what I’ve googled, it’s hard to come to a conclusion. I attempted doing this but dump1090-fa doesn’t seem to be able to decode anything.
I just have a server already running in the house that has a bunch of dockerized stuff running on it. I thought it’d be cool to have the raspberry pi be a dumb raw data forwarder and have the server doing the decoding.
pi@raspberrypi:~ $ sudo systemctl stop dump1090-mutability
pi@raspberrypi:~ $ rtl_tcp -a 192.168.0.21 -f 1090000000 -s 2000000 &
[1] 2144
pi@raspberrypi:~ $ Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Exact sample rate is: 2000000.052982 Hz
Tuned to 1090000000 Hz.
listening...
Use the device argument 'rtl_tcp=192.168.0.21:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...).
#AFTER STARTING TELNET ON WINDOWS DESKTOP:
client accepted!
ll+, now 1
ll+, now 2
ll+, now 3
ll+, now 4
ll+, now 5
ll+, now 6
ll+, now 7
ll+, now 8
ll+, now 9
ll+, now 10
C:\Windows\System32\cmd.exe
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\System32>telnet
Welcome to Microsoft Telnet Client
Escape Character is 'CTRL+]'
Microsoft Telnet> open 192.168.0.21 1234
Connecting To 192.168.0.21...
z } | Ç }} {~ }~| } }{ } Ç Ç~} ~} x xÇ }}Ç~{ Ç }y Ç } z} | ~x yzÇÇ { {~ } }z~r}xy}ÇÇ ~v}~{ z ÇÇ{ {}~|v
z yÇyx | } Ç ~ ~~ }w | zÇ| |} |}|~}| Ç }| {} | }~ ÇÇÇ } |} z~ y }w { |y|{y {Çy wÇ{}~ Ç{ Ç| z x|
{|Çy{Ç | Ç~|} w Ç~Ç~ w~ zz~|~ Ç Çz| {|}Ç ÇuyÇ ~x}zÇ|z } ~~Çz }|Çyy {{ÇÇ~ Çz z~ v | Ç~ {z z
Ç }z } ~ } | ~{~v Ç~w}|}z ~y Ç ~} | ~} { ~ {Ç|}yÇÇ } uÇ Ç | Çx{| |v} z } y Ç ~~ z||~ Ç}zz
Ç ~~ Ç Çzx| ~yÇ~}Ç}~ Ç{ yÇ| ~Ç |}{ Ç z w}}~Ç y~|y | {~ }~ { x~ Ç} { | Ç} z| z } z| { Ç ~ x } |Ç
}Ç}{yzy Ç{~~~Ç|{ ~ { Ç } | |y~ Ç ~Ç |Çw z { ~ ~~ ÇÇ ÇÇ{ w|~ ÇÇ} ÇÇ~|{|y |w |~Ç | }z}~x wtwÇ} } y Ç|~
z ÇÇy || Ç Ç~x } Ç} Ç Ç |~{~ z { x | { {Ç}w} }}z ~Çz{ uz |~} ~ } ~ ~Ç v ~}yy~}~| {zÇ~ } y}{Ç y
Ç|t~| Ç} Ç|~| ~} } z}zs Ç ÇÇ } y |~ |{Ç } u} }~ Ç~{Ç y ~ ~~y v zÇ~{ }| ÇÇ y} ~ }~ w yÇ~ z} ÇÇ
z~z Ç w}wxÇz}ÇÇ | ~ {~w ~ ~ |} } v { x } ÇÇ~| ~|| | }Ç~} ~ {| yÇy~x{Ç } }|Ç~Ç Ç | }~ | ~w } Ç}|Ç ~} Ç ~
} Ç|||Ç { |wy~z wwÇ zÇz|Ç{ Ç ~|} ÇÇ} ÇÇz x ~ ~Ç ~~~v|z} ~ x |xy }~} }}z { | z ~ zu~ }{ w ~Ç } z{
{~Ç | z ~ {v~w|Ç}| } Çxu~|w Ç yx | z } yw~ wÇ~y { } Çy |{u~}y{y } Ç x }}y } ÇÇ Çz~
}z Ç{ x Ç~{ {Ç ~ z{}{z {Ç{Çv{x }~ z { ~y ~| y}~| y| |ys Ç}z}~{ ~ | { Ç zv ~Ç } |}t{ Çy{}Ç} ~~~ ||{
| ~ | xy y xÇz | wÇv ~ ~~~} x } |z Ç}w| ~ } Ç}Ç ~ | Ç| || {}z{~ {Ç}} w Ç} ~ }}~w}Ç } {wÇz yÇz |~ {
}Ç Ç ~z |~Ç x}| Çz|ÇÇ q} ÇÇ} zz~} }~Ç}} } Ç |} Ç Ç| }} { { ~ t|{ Ç y} Ç |~z z }} {v w{|z |Ç~ z} Ç
~{y { |xzÇ ~ |Ç{{ uÇxy ~|Çy { ~~ Çy |Ç~Ç~y ~ ~ |z ||{ y~Çz| Ç | } xÇ{ w Ç }y ~ }Ç ~ zÇ { ~}
Ç } { Ç|zy } Ç} ÇÇ Ç | ~w} w y| Ç}}y} Ç ~| zÇ {~ z|}}} | z{ }}{} Ç }} y Ç| z ||}} ~}ry{ y
Ç{ }Ç~ ~ z~xÇ } ~ z xÇ{{~{|y | { yÇy| zÇ| } Ç|~ yÇz | z yz|zy{~ | wyv{x }}~ ~ ~} | Çxv z}
Ç~ Ç z Ç}}zÇÇ {v ~~| } u ~{ ~} ~ z|~~ ÇÇ Ç ~{x} z{ {ÇÇ{| } Ç ~Ç | Ç ~ Ç}~ z || { } }uÇ Ç|}ywÇx ||y~
{Ç}~ÇÇ} Ç{|}{ x~| ~ {zÇ{u Ç x || z x}} ~x v}{}v}y | } ~x xy }{~~~ wuxu |Ç Çx Çw |z}} Ç |~~~ Ç ~ x ÇÇ}~ yÇ
}} ~ ~} z}~||Ç| {z|z x~ | }{Çw| }~}z~y}}u}{Ç } z ~ x | Ç}|Ç z{{ z{ y|}Ç | ~z u}{~| vÇ|Ç z {} y|{|~
} { v{ { zu | |~}z ~y~ x { {}~ {yÇy|| }yÇz x}w{y zx Ç ÇzÇ| y y} { |Ç}}~ | z Ç}~Ç~~üüé~~|{é|Çâäçüë{zèéÇ{Çzäz|ü
~üÇ}{ééÇÇ{éy~ü~|}}}|ééàv|~}~ä}àx|äâê}é{}~â|éyÇ|üzzàxà~é{}ÇéäüÇÇ}~é|äâàäyÇÇà~zz~|à|é|åé|}||ü|é|~yé|êÇâ}ü}üé~|}üü}éü~~{çàä
tåéy~{|ÇâzâÇÇ}â}~ÇéçvâââÇyzÇå~Çz}~}àüé}â}}éÇzâÇüå{å|üàâçàüâäx|ä}å~ézÇyÇâ}~üééâ{éà{x}~{âü~åâéâ|~|äÇ~~Ç~yx}{é~|Ç~Ç}{éâ|âéä
}{é{äÄ}ëÇüÇâézääâäéëÇ|~|üÇäé~}üéàtyüüâ}~ÇÇé~~üäv}Çüàç}Ç{~ü}üüÇå~îÇ}ü~~}|}wzw~~é~}üäüä}å~üâàâüÇ}ääâäà~ÇÇ~âäââyäïÇ{üy~wÇwë
#AFTER CLOSING SSH WINDOW OF RPI
Connection to host lost.
Press any key to continue...
You can run dump1090 on the Pi and piaware elsewhere if you like, which is closer to that model and a lot cheaper in terms of bandwidth. I am not sure how reliable the Pi’s USB is going to be (which is important for mlat) if you have two copies of the I/Q data running over it at 5MB/s each (the Pi’s ethernet is on the USB bus)
IQ feed to dump1090.exe (MR) on Windows 8 computer
RESULT: dump1090.exe runs for few seconds, displays data of few planes, then stops for unknown reason worker socket bye
Signal caught, exiting!
comm recv bye
all threads dead…
Linux command to Windows 8 computer using MobaXterm running on Windows 8 computer.
No DVB-T Dongle plugged into Windows Desktop.
