I just installed piaware on an existing Pi4 and everything seems to be working and is recognized on Flightaware but my RTL-SDR V4 is not putting out any data on dump1090. Here is the result of piaware-status…
PiAware master process (piaware) is running with pid 23996.
PiAware ADS-B client (faup1090) is running with pid 326914.
PiAware mlat client (fa-mlat-client) is running with pid 128435.
Local ADS-B receiver (dump1090-fa) is running with pid 326659.
dump1090-fa (pid 326659) is listening for ES connections on port 30005.
And lsusb…
admin@MQTTraspberrypi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And …
admin@MQTTraspberrypi:~ $ sudo systemctl status dump1090-fa -l
* dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; preset: enabled)
Active: active (running) since Thu 2025-05-22 17:04:24 PDT; 1h 1min ago
Main PID: 326659 (dump1090-fa)
Tasks: 3 (limit: 3913)
Memory: 3.0M
CPU: 7min 17.940s
`-326659 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --gain 60 --adaptive-range --fix --lat 50.45228 --lon -119.38985 --max-range 360 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 300>
May 22 17:04:24 MQTTraspberrypi dump1090-fa[326659]: Detached kernel driver
May 22 17:04:24 MQTTraspberrypi dump1090-fa[326659]: Found Rafael Micro R828D tuner
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: rtlsdr: tuner gain set to about 58.6 dB (gain step 29) (tuner AGC enabled)
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: [R82XX] PLL not locked!
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: adaptive: using 50% duty cycle
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: adaptive: enabled adaptive gain control with gain limits 0.0dB (step 0) .. 58.6dB (step 29)
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: adaptive: enabled dynamic range control, target dynamic range 30.0dB
May 22 17:04:25 MQTTraspberrypi dump1090-fa[326659]: Allocating 4 zero-copy buffers
May 22 17:04:35 MQTTraspberrypi dump1090-fa[326659]: adaptive: reached upper gain limit, halting dynamic range scan here
lines 1-21/21 (END)
I have searched for the piaware-config file but can’t find it anywhere. I installed the program using @abcd567 method posted here a year or so ago. Found here…
The rtl-sdr.com v4 uses a different chip from most of the other rtl devices. It requires special drivers to work with most software.
See details here and tips on how to install those v4 specific drivers. Note that these “v4” drivers will be backwards compatible with all the rtl devices, so it will not cause any problems. I have two of the v4. They are not ideal for 1090, but do work fine.
Okay cool, thank you found that one, it’s empty except for instructions. I’ll need to find all things that need to go in there, maybe it’s just the few lines telling it to look for rtl-sdr and to auto update.
Need to thank you for all your work here to help us get this working, I have seen MANY posts and such you have made over the years, really appreciate the effort.
admin@MQTTraspberrypi:~ $ sudo piaware-status
PiAware master process (piaware) is running with pid 1105.
PiAware ADS-B client (faup1090) is running with pid 1316.
PiAware mlat client (fa-mlat-client) is running with pid 4972.
Local ADS-B receiver (dump1090-fa) is running with pid 781.
dump1090-fa (pid 781) is listening for ES connections on port 30005.
Your feeder ID is xxxxxxxxxxxxxxxxxxxxxxxxxxxxx (configured at /etc/piaware.conf:17)
Please know that I am only 6 months into learning Linux, computer savvy but Linux deprived.
I followed the instructions given on that page verbatum and here are the results…
PiAware master process (piaware) is running with pid 1132.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for ES connections on port 30005.
got 'couldn't open socket: connection refused'
Otherwise piaware-status is kinda inadequate to see what is going on.
As root, looking at the dump1090-fa log will be more useful:
sudo su -
journalctl -u dump1090-fa
piaware status was showing dump1090-fa was running before you tried to install the drivers
Oh, apparently the previous instructions didn’t mention it, you have to use this section of the guide at RTL-SDR Blog V4 Users Guide
Alternative Debian Package Installation Method
Otherwise it’s just not gonna work with most software as they require the driver package to be installed as a dependency.
After doing that you will have to reinstall dump1090-fa.
I think you are onto something here…so for me, newbie Linux guy, how do I undo what I did in the first section of those instructions, before I implement the section you mentioned? Or can I just run the second method and it will “fix” what didn’t work in the first method?
I’m hoping Linux doesn’t operate like windoze in that everything you do continues to bloat the registry and clog up the system, no matter what.
That shouldn’t happen regardless of drivers.
Might be an issue with the SDR / USB extension / voltage.
Just run the package install method in the guide and install dump1090-fa after that.
I’m … experienced but when it comes to installing libraries without a package, that’s painful to undo.
Just do the other thing and it should be fine.
If you have a Raspbian bookworm, might be that the rtl-sdr library actually support v4 without having to install the other driver. But maybe that will be the next version i’m not sure.
Please upgrade your dump1090-fa to latest ver 10.0.1.
Your current idump1090-fa is too old (ver 8.2), and it is for wrong version of OS, i.e. for Stretch, while your OS is Bookworm.
Please use following commands to upgrade dump1090-fa:
Okay, progress! We are back to where we were yesterday morning, everything seems to be working but no dump data.
PiAware master process (piaware) is running with pid 1110.
PiAware ADS-B client (faup1090) is running with pid 1286.
PiAware mlat client (fa-mlat-client) is running with pid 5717.
Local ADS-B receiver (dump1090-fa) is running with pid 764.
dump1090-fa (pid 764) is listening for ES connections on port 30005.
I’ll keep researching to try and find the answer.
Thank you
I’m out of posts for a new user…adding on here…
It seems dump1090 didn’t update…it’s still dump1090-fa 8.2~bpo9+1
here’s the result of journalctl -u dump1090-fa
dump1090-fa.service: Scheduled restart job, restart counter is at 6.
May 22 11:10:46 MQTTraspberrypi systemd[1]: Stopped dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization).
May 22 11:10:46 MQTTraspberrypi systemd[1]: Started dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization).
May 22 11:10:46 MQTTraspberrypi dump1090-fa[10091]: Thu May 22 11:10:46 2025 PDT dump1090-fa 8.2~bpo9+1 starting up.
May 22 11:10:46 MQTTraspberrypi dump1090-fa[10091]: rtlsdr: no supported devices found.
May 22 11:10:46 MQTTraspberrypi systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 22 11:10:46 MQTTraspberrypi systemd[1]: dump1090-fa.service: Failed with result 'exit-code'.
FIXED! And working.
After removing old packages, fix broken packages and installing the RTL drivers per the second method, reinstalling dump1090, and a few other things I can’t recall it’s up and running and producing data live.
Thank you so much everyone for your help, I hope I’ll be able to help someone in my position someday after I learn a LOT more.
It’s been up and running all day, just wanted to say thanks again to all who helped, I really appreciate your time.
I’m now researching how to see RSSI on the main screen of Skyaware. I’ll probably post another thread. Being an RF engineer, I like to see this sort of detail.
