Hi,
Long time Reader first time poster here. ![]()
A number of years ago I made a Cantenna, mounted at about 35 m inside my loft. Approximate 5m WF100 down lead to generic cheap TV tuner, connected to a Raspberry Pi.
This gave me around 800 aircraft a day, A maximum range of 155 nautical miles, and an average range of around 100nm. Gain set too max (Based in the Vale of York, the topography of the land Is against me in most directions)
After around three years, I’ve decided to revisit this and replaced the homebrew antenna with a commercial one from the pie hut.
It was mounted in the same position, and my range didn’t really increase but the number of aircraft increase to around 1000 a day.
Disappointed with this, I moved the pi Into the loft shortening the lead to the antenna to around 1.1m, The range immediately increased to max of 175nm, and I was frequently seeing A daily maximum range of 165 nautical miles.
(Occasionally, ones are over 300, but they were rare)
After this performed consistently for a week, I decided to connect the receiver directly to the base of the antenna. Thinking this would remove more attenuation in the Cable, however my range dropped to 5nm, The number of detected aircraft was less than 20 a day!
So I very quickly replaced the original cable, and the range returned back to the previous values.
I then tried shortening the lead to around 85cm to tidy up any trailing cables in the loft rather than any specific theory about the range. I then noticed that my daily maximum range had dropped to 150nm, I was no longer seeing anything around the 165 miles to the 175 range. (Thinking I should stuck to the Can!)
I have now tried a cable at approximately 1.35 m, which is around 10 half wavelengths. Detections have increased by about 10 -15% (1200 daily) with no increase in range, it’s now sat at 138nm…
What can I do to boost the range?
Was I just lucky with 1.1m? Or did I hit some magic multiple of wave lengths?
Im assuming my issue is related to interference? There is very little local traffic with airports all been 30mikes away.
Would I be better purchasing a filter for around £25. I read good reviews about these.
Or buying the FA ProStick Plus as this has a filter and a LNA… would this then be happy connected to the base of the antenna?
Thanks ![]()
