Colors too bright
Sometimes, seeing the difference between the light blue and lime green flight paths is difficult to tell, especially when you look at it from a short distance , or when you look at an airport with only a few flights coming to it, they look the same. Please have an option so that each registered user can change the colors of the arriving/departing flights (blue) or the in airspace flights (green), or just change the colors so that the difference is easier to see, and so our older veiwers (not me-yet) can enjoy this tracker.
Thank you
I haven’t had any problems whatsoever with the colors using three different monitors (2 desktops and a laptop). Have you checked your monitor?
I would suggest one improvement, though. The bottom of the screen says: Flights in blue are to/from KXXX; flights in green are in the vicinity.
I would change this so it reads Flights in blue are to/from KXXX; flights in green are in the vicinity. To put it another way, the colors should be in the color mentioned. This way if someone does have a problem telling the colors apart, they can use the key as a way of matching up the colors by comparing the words green with the lines that are green.
