My first post. I am totally new to ADS-B; just bought a FlightAware USB stick pro and an antenna and want to play around with them.
I am software developer, so would welcome advice for other coders.
Basically, I wan to read the data from my FlightAware, send it my server and place it into a database whence various software which I code can read it, manipulate it, display it, send alerts - the usual stuff.
I would strongly prefer to develop in Windows, falling back to Linux if that won’t work, and, as last choice, the Raspberry Pi (4 or Zero W).
Is it as simple as just opening a serial port and reading? Would I be advised to run dump1090 and process its output?
I am itching to get coding. Any advice on how best to proceed will be gratefully accepted
Yes.
Reading the aircraft.json is probably be the way to go. (not sure if dump1090-mr has that even)
dump1090-fa which doesn’t run on Windows i think (not sure, try and compile) has some more fields, but not sure which info you need.
Maybe just read the code of dump1090 … that will tell you how it interfaces with the SDR.
Thanks for a quick and informative reply. I appreciate that a lot of effort has gone into the development of dump1090, and have no desire to reinvent the wheel.
My initial reaction was to link the dump1090 into my own app, but, on reflection, I may as well run it from the command line and capture its output/redirect its output into my app.
Since I am using Windows for most of my development work, I will try in a Linux VM run from Windows. I don’t really see the need for the Raspberry Pi (yet).
If you want to do it for processing the data only, there are already some Python scripts available on GitHub which are capable to get the output of aircraft.json and write it to a database.
There are already some experts who adapted dump1090 onto a Linux/Ubuntu machine. But i don’t know if the VM will get full access to the hardware stick of the host device
Check for user @abcd567 here in Forum . He did it with the current Piaware build 3.8.1 a few days ago.
You can also find parts of the discussion on the new build release announcement here in Forum.
Depends what level of hardware access is required. Some low-level devices cannot be virtualized. But i have no idea if an RTL stick is part of it.
I have been using this for a while, writing the output to a MySQL db. Worked very good. I stopped it due to the pure amount of data generated.
Virtual serial port? That’s not how the rtl-sdr USB sticks transfer data …
And compiling dump1090-fa on Ubuntu / Debian really isn’t that hard.
If you aren’t able to just check the github readme for dump1090-fa on how you compile it … and stick with it for a bit …
you can use this script which should compile a dump1090-fa fork which provide pretty much the same aircraft.json: Automatic installation for readsb · wiedehopf/adsb-scripts Wiki · GitHub
