Any ideas on this one please? This has been ongoing for ages but I have only just got round to enquiring how to get it fixed. The problem is indicated when the “view anomalies” message is showing in the site info bar at the top of the webpage
May 03 14:32:25 raspberrypi piaware[1933]: adept reported location: 51.48599, 0.07680, 108ft AMSL
May 03 14:32:25 raspberrypi piaware[1933]: logged in to FlightAware as user slammer99uk
May 03 14:32:25 raspberrypi piaware[1933]: my feeder ID is 78daa340-8051-4098-a7aa-0fc2a1e52288
May 03 14:32:25 raspberrypi piaware[1933]: site statistics URL: slammer99uk ADS-B Feeder Statistics - FlightAware
May 03 14:32:26 raspberrypi piaware[1933]: multilateration data requested
May 03 14:32:26 raspberrypi sudo[1970]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
May 03 14:32:26 raspberrypi sudo[1970]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 03 14:32:26 raspberrypi sudo[1970]: pam_unix(sudo:session): session closed for user root
May 03 14:32:26 raspberrypi piaware[1933]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.80.206:17143:4266385111
May 03 14:32:26 raspberrypi piaware[1933]: piaware has successfully sent several msgs to FlightAware!
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): fa-mlat-client 0.2.12 starting up
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Using UDP transport to 206.253.80.206 port 17143
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Listening for Beast-format results connection on port 30105
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Listening for Extended Basestation-format results connection on port 30106
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Route MTU changed to 1500
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Input connected to localhost:30005
May 03 14:32:26 raspberrypi piaware[1933]: mlat-client(1978): Input format changed to BEAST, 12MHz clock
May 03 14:32:27 raspberrypi piaware[1933]: mlat-client(1978): Beast-format results connection with ::1:30104: connection established
May 03 14:32:56 raspberrypi piaware[1933]: 729 msgs recv’d from dump1090-fa; 721 msgs sent to FlightAware
May 03 14:33:27 raspberrypi piaware[1933]: NOTICE from adept server: 32% of multilateration messages (UDP) are not reaching the server - check your network?
May 03 14:34:28 raspberrypi piaware[1933]: NOTICE from adept server: 30% of multilateration messages (UDP) are not reaching the server - check your network?
