Hi,
I’m a newbie with Raspberri Pi and recently got my first PI ( Raspberry Pi 4 Model B - 8GB RAM) and it’s connected to my Meraki Switch via ethernet cable and I have a Rtl-SDR dongle and have the 15 watt official PI Power supply .
My network is a WiFi Cable Modem Router (C3700) and a Meraki Security Appliance( MX64) and Switch (MS120-8LP) and Wireless AP (MR33).
Wifi is disabled under the Cable Modem ( i run WIFI from the Meraki AP and i have turned off Wifi on the PI and kept only ethernet access )
I have Piaware 5.0 running and i have notice that i get a lot of anomalies error message under my site and wondering on how i could fix it. i did some googling research but been a newbie i wanted to get some opinions.
I did power cycle my Switch, AP and SA as part of the troubleshooting but i keep seeing the error message about UDP multilateration traffic .
I did run a ping from the Meraki Dashboard and i got : Loss rate: 30 % Average latency: 62 ms
I have included the Piaware log for review as well and would appreciate any feedback
[2021-03-12 06:02 EST] 2927 msgs recv’d from dump1090-fa (240 in last 5m); 2921 msgs sent to FlightAware
[2021-03-12 06:07 EST] 3207 msgs recv’d from dump1090-fa (280 in last 5m); 3201 msgs sent to FlightAware
[2021-03-12 06:12 EST] 3406 msgs recv’d from dump1090-fa (199 in last 5m); 3400 msgs sent to FlightAware
[2021-03-12 06:13 EST] mlat-client(1023): Server status: synchronized with 320 nearby receivers
[2021-03-12 06:13 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 06:13 EST] mlat-client(1023): Aircraft: 3 of 3 Mode S, 4 of 4 ADS-B used
[2021-03-12 06:13 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
[2021-03-12 06:13 EST] mlat-client(1023): Receiver: 44.6 msg/s received 18.6 msg/s processed (42%)
[2021-03-12 06:17 EST] 3536 msgs recv’d from dump1090-fa (130 in last 5m); 3530 msgs sent to FlightAware
[2021-03-12 06:22 EST] 3663 msgs recv’d from dump1090-fa (127 in last 5m); 3657 msgs sent to FlightAware
[2021-03-12 06:27 EST] 3934 msgs recv’d from dump1090-fa (271 in last 5m); 3928 msgs sent to FlightAware
[2021-03-12 06:28 EST] mlat-client(1023): Results: 0.3 positions/minute
[2021-03-12 06:28 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 06:28 EST] mlat-client(1023): Receiver: 24.7 msg/s received 9.3 msg/s processed (38%)
[2021-03-12 06:28 EST] mlat-client(1023): Server status: synchronized with 365 nearby receivers
[2021-03-12 06:28 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
[2021-03-12 06:28 EST] mlat-client(1023): Aircraft: 1 of 1 Mode S, 9 of 9 ADS-B used
[2021-03-12 06:32 EST] 4132 msgs recv’d from dump1090-fa (198 in last 5m); 4126 msgs sent to FlightAware
[2021-03-12 06:37 EST] 4240 msgs recv’d from dump1090-fa (108 in last 5m); 4234 msgs sent to FlightAware
[2021-03-12 06:42 EST] 4388 msgs recv’d from dump1090-fa (148 in last 5m); 4382 msgs sent to FlightAware
[2021-03-12 06:43 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 06:43 EST] mlat-client(1023): Aircraft: 3 of 3 Mode S, 3 of 3 ADS-B used
[2021-03-12 06:43 EST] mlat-client(1023): Receiver: 26.0 msg/s received 9.9 msg/s processed (38%)
[2021-03-12 06:43 EST] mlat-client(1023): Server status: synchronized with 274 nearby receivers
[2021-03-12 06:43 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
[2021-03-12 06:47 EST] 4479 msgs recv’d from dump1090-fa (91 in last 5m); 4473 msgs sent to FlightAware
[2021-03-12 06:52 EST] 4555 msgs recv’d from dump1090-fa (76 in last 5m); 4549 msgs sent to FlightAware
[2021-03-12 06:57 EST] 4653 msgs recv’d from dump1090-fa (98 in last 5m); 4647 msgs sent to FlightAware
[2021-03-12 06:58 EST] mlat-client(1023): Server status: synchronized with 261 nearby receivers
[2021-03-12 06:58 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
[2021-03-12 06:58 EST] mlat-client(1023): Receiver: 16.1 msg/s received 7.7 msg/s processed (48%)
[2021-03-12 06:58 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 06:58 EST] mlat-client(1023): Aircraft: 1 of 1 Mode S, 4 of 4 ADS-B used
[2021-03-12 07:02 EST] 4759 msgs recv’d from dump1090-fa (106 in last 5m); 4753 msgs sent to FlightAware
[2021-03-12 07:07 EST] 4819 msgs recv’d from dump1090-fa (60 in last 5m); 4813 msgs sent to FlightAware
[2021-03-12 07:12 EST] 4838 msgs recv’d from dump1090-fa (19 in last 5m); 4832 msgs sent to FlightAware
[2021-03-12 07:13 EST] mlat-client(1023): Aircraft: 1 of 1 Mode S, 2 of 2 ADS-B used
[2021-03-12 07:13 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
[2021-03-12 07:13 EST] mlat-client(1023): Receiver: 8.1 msg/s received 3.9 msg/s processed (48%)
[2021-03-12 07:13 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 07:13 EST] mlat-client(1023): Out-of-order timestamps: 1
[2021-03-12 07:13 EST] mlat-client(1023): Server status: not synchronized with any nearby receivers
[2021-03-12 07:17 EST] 4940 msgs recv’d from dump1090-fa (102 in last 5m); 4934 msgs sent to FlightAware
[2021-03-12 07:22 EST] 5104 msgs recv’d from dump1090-fa (164 in last 5m); 5098 msgs sent to FlightAware
[2021-03-12 07:27 EST] 5354 msgs recv’d from dump1090-fa (250 in last 5m); 5348 msgs sent to FlightAware
[2021-03-12 07:28 EST] mlat-client(1023): Receiver: 30.7 msg/s received 12.2 msg/s processed (40%)
[2021-03-12 07:28 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
[2021-03-12 07:28 EST] mlat-client(1023): Server status: synchronized with 351 nearby receivers
[2021-03-12 07:28 EST] mlat-client(1023): Aircraft: 1 of 1 Mode S, 9 of 9 ADS-B used
[2021-03-12 07:28 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 07:32 EST] 5622 msgs recv’d from dump1090-fa (268 in last 5m); 5616 msgs sent to FlightAware
[2021-03-12 07:37 EST] 5844 msgs recv’d from dump1090-fa (222 in last 5m); 5838 msgs sent to FlightAware
[2021-03-12 07:42 EST] 6079 msgs recv’d from dump1090-fa (235 in last 5m); 6073 msgs sent to FlightAware
[2021-03-12 07:43 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 07:43 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
[2021-03-12 07:43 EST] mlat-client(1023): Server status: synchronized with 362 nearby receivers
[2021-03-12 07:43 EST] mlat-client(1023): Results: 0.4 positions/minute
[2021-03-12 07:43 EST] mlat-client(1023): Receiver: 56.8 msg/s received 19.9 msg/s processed (35%)
[2021-03-12 07:43 EST] mlat-client(1023): Aircraft: 2 of 2 Mode S, 14 of 14 ADS-B used
[2021-03-12 07:47 EST] 6401 msgs recv’d from dump1090-fa (322 in last 5m); 6395 msgs sent to FlightAware
[2021-03-12 07:52 EST] 6716 msgs recv’d from dump1090-fa (315 in last 5m); 6710 msgs sent to FlightAware
[2021-03-12 07:57 EST] 6913 msgs recv’d from dump1090-fa (197 in last 5m); 6907 msgs sent to FlightAware
[2021-03-12 07:58 EST] mlat-client(1023): Receiver: 46.6 msg/s received 19.0 msg/s processed (41%)
[2021-03-12 07:58 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 07:58 EST] mlat-client(1023): Server status: synchronized with 304 nearby receivers
[2021-03-12 07:58 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
[2021-03-12 07:58 EST] mlat-client(1023): Aircraft: 4 of 5 Mode S, 4 of 4 ADS-B used
[2021-03-12 08:02 EST] 7080 msgs recv’d from dump1090-fa (167 in last 5m); 7074 msgs sent to FlightAware
[2021-03-12 08:07 EST] 7271 msgs recv’d from dump1090-fa (191 in last 5m); 7265 msgs sent to FlightAware
[2021-03-12 08:12 EST] 7480 msgs recv’d from dump1090-fa (209 in last 5m); 7474 msgs sent to FlightAware
[2021-03-12 08:13 EST] mlat-client(1023): Server status: synchronized with 309 nearby receivers
[2021-03-12 08:13 EST] mlat-client(1023): Receiver status: connected
[2021-03-12 08:13 EST] mlat-client(1023): Receiver: 34.0 msg/s received 13.8 msg/s processed (41%)
[2021-03-12 08:13 EST] mlat-client(1023): Aircraft: 3 of 3 Mode S, 4 of 4 ADS-B used
[2021-03-12 08:13 EST] mlat-client(1023): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
[2021-03-12 08:15 EST] multilateration data requested
[2021-03-12 08:15 EST] mlat-client(30970): Route MTU changed to 1500
[2021-03-12 08:15 EST] mlat-client(30970): Input connected to localhost:30005
[2021-03-12 08:15 EST] mlat-client(30970): Listening for Beast-format results connection on port 30105
[2021-03-12 08:15 EST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.156:11699:757755392
[2021-03-12 08:15 EST] mlat-client(30970): Using UDP transport to 70.42.6.156 port 11699
[2021-03-12 08:15 EST] logged in to FlightAware as user
[2021-03-12 08:15 EST] mlat-client(30970): Listening for Extended Basestation-format results connection on port 30106
[2021-03-12 08:15 EST] my feeder ID is 40408989-16f1-4254-8087-1d04c26e706d
[2021-03-12 08:15 EST] mlat-client(30970): Input format changed to BEAST, 12MHz clock
[2021-03-12 08:15 EST] site statistics URL: https://flightaware.com/adsb/stats/user/#stats-148540
[2021-03-12 08:15 EST] mlat-client(30970): fa-mlat-client 0.2.11 starting up
[2021-03-12 08:15 EST] mlat-client(30970): Beast-format results connection with ::1:30104: connection established
[2021-03-12 08:19 EST] site statistics URL: https://flightaware.com/adsb/stats/user/#stats-148540
[2021-03-12 08:19 EST] mlat-client(31646): Listening for Extended Basestation-format results connection on port 30106
[2021-03-12 08:19 EST] mlat-client(31646): Listening for Beast-format results connection on port 30105
[2021-03-12 08:19 EST] logged in to FlightAware as user
[2021-03-12 08:19 EST] mlat-client(31646): Route MTU changed to 1500
[2021-03-12 08:19 EST] my feeder ID is 40408989-16f1-4254-8087-1d04c26e706d
[2021-03-12 08:19 EST] multilateration data requested
[2021-03-12 08:19 EST] mlat-client(31646): Using UDP transport to 70.42.6.225 port 12766
[2021-03-12 08:19 EST] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.225:12766:3544714823
[2021-03-12 08:19 EST] mlat-client(31646): Input connected to localhost:30005
[2021-03-12 08:19 EST] mlat-client(31646): fa-mlat-client 0.2.11 starting up
[2021-03-12 08:19 EST] mlat-client(31646): Input format changed to BEAST, 12MHz clock
[2021-03-12 08:20 EST] mlat-client(31646): Beast-format results connection with ::1:30104: connection established
[2021-03-12 08:22 EST] 7969 msgs recv’d from dump1090-fa (267 in last 5m); 7788 msgs sent to FlightAware
[2021-03-12 08:27 EST] 8303 msgs recv’d from dump1090-fa (334 in last 5m); 8122 msgs sent to FlightAware
[2021-03-12 08:32 EST] 8578 msgs recv’d from dump1090-fa (275 in last 5m); 8397 msgs sent to FlightAware
[2021-03-12 08:35 EST] mlat-client(31646): Server status: synchronized with 268 nearby receivers
[2021-03-12 08:35 EST] mlat-client(31646): Results: 0.2 positions/minute
[2021-03-12 08:35 EST] mlat-client(31646): Aircraft: 3 of 3 Mode S, 6 of 7 ADS-B used
[2021-03-12 08:37 EST] 8862 msgs recv’d from dump1090-fa (284 in last 5m); 8681 msgs sent to FlightAware
[2021-03-12 08:42 EST] 9125 msgs recv’d from dump1090-fa (263 in last 5m); 8944 msgs sent to FlightAware
[2021-03-12 08:50 EST] mlat-client(31646): Receiver: 35.7 msg/s received 14.1 msg/s processed (39%)
[2021-03-12 08:50 EST] mlat-client(31646): Server status: synchronized with 302 nearby receivers
[2021-03-12 08:50 EST] mlat-client(31646): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
[2021-03-12 08:52 EST] 9467 msgs recv’d from dump1090-fa (140 in last 5m); 9286 msgs sent to FlightAware
[2021-03-12 08:57 EST] 9550 msgs recv’d from dump1090-fa (83 in last 5m); 9369 msgs sent to FlightAware
