Hi, i would like to change the IP adress of my FlightFeeder but unfortunately the screen doesn’t work anymore. Not displaying content and no reaction to touch. How can i change the config ?
Does your Flight Feeder have a HDMI port on it? If so you should likely be able to connect that port to an HDMI input on a tv and get the display output on the tv to view things. Are you not using a micro SD card in the flight feeder to house the config file so you could pull the card and edit the config file?
FlightFeeders are the FA-supplied units that come enclosed in a case. Accessing the SD card would require disassembling their case. I have one of the 978 versions and the case does give access to the HDMI port though.
